Align buttons to the right
I want to add a button to the bottom right.
What I've done is add a group box
Then inside it added another group box, (aligned to the right) as well as the buttons.
This works, but unfortunately, even if you make the group box flat, it still draws a line along the top, so this setup looks like a hack.
  • YudinEdYudinEd Posts: 90
    edited June 2018
    You can use for your button of group box YourButton
    YourButton.setGeometry (X coordinates, Y coordinates, width, height)
    or
    YourButton.x=  X coordinates
    YourButton.y = Y coordinates
    Post edited by YudinEd on
  • HowieFarkesHowieFarkes Posts: 640
    You don't always need to use a DzGroupBox as a container for other widgets when sometimes just a simple DzWidget will do the job (with the added bonus that a DzWidget will not be drawn with a border). You can still add layouts to DzWidget objects too.
  • BradCarstenBradCarsten Posts: 856
    Thanks YudinEd and HowieFarkes. That helps a lot.
