Rssy 3delight to iray converter
Will it do mirrors.  Can you see what is refelected......
  • kksmith6515kksmith6515 Posts: 201
    Good question! I don't know the answer though cause I just purchased it last night and haven't had a chance to work with it yet.
  • Anyonre else!!  I wont purchase if it wont do mirrors.
  • RedzRedz Posts: 1,459
    I don’t see a mirror shader preset, and testing on a surface named ‘mirror’ the script selects the general Iray shader. You can create/add your own presets, though this would require some additional work on your part.
  • TooncesToonces Posts: 919
    If you go to Smart Content > Shaders > Iray and search for mirror, you can see if you already have a mirror shader. Then, it's easy enough to just add a line to the script options to always use your mirror shader if it sees the word 'mirror' for any material surface. In fact, I think I'll do that now.
    So ya, it might not do mirrors out of the box, but the ability to add options to permanantly update the script's 'intelligence' is a super nice feature.
    edited June 2018
    In doing this, stumbled over a couple minor bugs:
    - Select All/None checks/unchecks everything, implying the checkmark = selection. But Clear Selected Matches button ignores the checkmark and operates purely on which rows are currently highlighted. Not a big deal, was just a bit confusing.
    - Skydome in options defaults to something weird test folder in E directory. I don't have an E directory. I updated it to point to this instead: "Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 18 Light White Iray.duf", and seems to have fixed it. Hopefully, updates to this product will not blow away changes users make to options...
    I added mirror option just to confirm it works and it does! It remembers it after closing/reopening Daz. Again, hoping product updates won't nuke customization tho. For those who want to add mirror, here is the line I used:
    Pattern: .*([Mm][Ii][Rr][Rr][Oo][Rr]).*
    Preset: Shader Presets/iray/jg/homestyle 2/mirror/hs2 mirror.duf
    Post edited by Toonces on
  • scorpioscorpio Posts: 8,533
    edited June 2018
    Post edited by scorpio on
  • AlfawulfAlfawulf Posts: 174
    I did the 1,2,3 on a fight scene of mine with it and it turned out looking crappy!!
    Nothing like the promo images..
    Maybe i did something wrong...maybe I don't fully understand it.
    Maybe I should post this elsewhere...
    Bottom line is first time out it disappointed me miserably.
  • jedijuddjedijudd Posts: 606
    I had high hopes for this, tries several scenes  but like Alfawulf said it turned out really bad will likely return for refund
    Yeah, I had a similar experience but I'm going to post my render in the tech support forum. I know so little about shaders and how they work, I might be doing something wrong.
  • Oso3DOso3D Posts: 15,115
    Once I figured out I had to move new filters above the catchall filter, worked like a charm!
    I converted Enchanted Forest with ease, once I added ivy, fern, and tropic to the filters.
    how do you add to the script?????
  • ddyackddyack Posts: 15
    edited July 2018
    I get an error when trying to run the script converstion and it spews a pile of errors in the debug file - any ideas wher could be going on?  I tried installing and reinstalling from DAZ install manager but it does not seem to work.  Still pretty new to DAZ here.
    2018-07-08 08:29:00.080 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:00.082 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:00.083 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:00.086 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:00.086 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB2018-07-08 08:29:01.089 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.091 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.102 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.103 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.104 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.105 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.106 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.108 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.109 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.119 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.121 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.122 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.123 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.124 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.125 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.126 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.136 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.137 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.138 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.139 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.139 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.140 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.141 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.146 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.147 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.148 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.148 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.149 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.149 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.150 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.155 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.156 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.160 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.161 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.162 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.199 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.201 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.208 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB2018-07-08 08:29:01.209 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.220 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.221 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.259 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.260 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.360 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:01.941 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.051 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.053 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.055 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.080 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.082 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:02.083 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:05.276 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/3dl to iray/rssy 3delight to iray.dse2018-07-08 08:29:05.319 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-07-08 08:29:05.339 DEBUG: InitializeDialog2018-07-08 08:29:05.349 DEBUG: LoadListViewFromSettings( settings, listView, prefix )2018-07-08 08:29:05.350 DEBUG: <Settings> <Setting Type="SubSetting" Key="Match">  <Setting Type="SubSetting" Key="Match 1">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">#blMilWom_v4b_68498</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Figure Materials/Generation 4/RSSY3DLtI 01 Victoria 4 Material Iray.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 2">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Base</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 3">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">black</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 4">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">dress</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 5">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressCloth</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 11 Fabric Slick Iray.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 6">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressClothInner</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 11 Fabric Slick Iray.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 7">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressEdge</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 8">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressFrill1</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 9">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressFrill2</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 10">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressFrill3</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 11">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressFrill4</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 12">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressRibbons</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 13">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">DressRings</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 14">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">EdgeSt</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 15">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Floor01</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 16">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">FloorMid</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 17">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Hair</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 12 Hair Iray.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 18">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">handles</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 19">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">JacketBow</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 20">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">JacketCloth</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 11 Fabric Slick Iray.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 21">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">JacketEdge</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 22">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Long1</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 23">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Long2</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 24">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">SkirtEdges</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 25">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">SkirtJewel</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 26">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">SkirtMain</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 27">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">SkirtOrnament</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting>  <Setting Type="SubSetting" Key="Match 28">   <Setting Type="Bool" Key="Active">yes</Setting>   <Setting Type="String" Key="3DL Material/Figure">Tongue</Setting>   <Setting Type="String" Key="Conversion Preset">Shader Presets/RSSY 3Delight to Iray Converter/Shaders/RSSY3DLtI 01 General Iray Shader.duf</Setting>  </Setting> </Setting></Settings> [object Object] Match 2018-07-08 08:29:05.359 DEBUG: Reading Match 12018-07-08 08:29:05.359 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.359 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.359 DEBUG: Reading Match 22018-07-08 08:29:05.359 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.359 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.359 DEBUG: Reading Match 32018-07-08 08:29:05.359 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.359 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.359 DEBUG: Reading Match 42018-07-08 08:29:05.367 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.367 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.367 DEBUG: Reading Match 52018-07-08 08:29:05.367 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.367 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.367 DEBUG: Reading Match 62018-07-08 08:29:05.367 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.368 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.368 DEBUG: Reading Match 72018-07-08 08:29:05.368 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.375 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.375 DEBUG: Reading Match 82018-07-08 08:29:05.375 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.375 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.375 DEBUG: Reading Match 92018-07-08 08:29:05.375 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.375 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.375 DEBUG: Reading Match 102018-07-08 08:29:05.375 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.375 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.379 DEBUG: Reading Match 112018-07-08 08:29:05.379 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.380 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.380 DEBUG: Reading Match 122018-07-08 08:29:05.380 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.380 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.380 DEBUG: Reading Match 132018-07-08 08:29:05.380 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.380 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.380 DEBUG: Reading Match 142018-07-08 08:29:05.383 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.383 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.383 DEBUG: Reading Match 152018-07-08 08:29:05.383 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.383 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.383 DEBUG: Reading Match 162018-07-08 08:29:05.383 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.383 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.383 DEBUG: Reading Match 172018-07-08 08:29:05.383 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.386 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.386 DEBUG: Reading Match 182018-07-08 08:29:05.386 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.386 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.386 DEBUG: Reading Match 192018-07-08 08:29:05.386 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.387 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.387 DEBUG: Reading Match 202018-07-08 08:29:05.387 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.387 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.390 DEBUG: Reading Match 212018-07-08 08:29:05.390 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.390 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.390 DEBUG: Reading Match 222018-07-08 08:29:05.390 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.390 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.390 DEBUG: Reading Match 232018-07-08 08:29:05.390 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.390 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.390 DEBUG: Reading Match 242018-07-08 08:29:05.393 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.393 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.393 DEBUG: Reading Match 252018-07-08 08:29:05.393 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.393 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.393 DEBUG: Reading Match 262018-07-08 08:29:05.393 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.393 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.393 DEBUG: Reading Match 272018-07-08 08:29:05.393 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.396 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.396 DEBUG: Reading Match 282018-07-08 08:29:05.396 DEBUG: Reading 3DL Material/Figure2018-07-08 08:29:05.396 DEBUG: Reading Conversion Preset2018-07-08 08:29:05.396 WARNING: Script Error: Line 2352018-07-08 08:29:05.396 WARNING: ReferenceError: Can't find variable: LoadFileToArray2018-07-08 08:29:05.396 WARNING: Stack Trace:	<anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/3dl to iray/rssy 3delight to iray.dse:2352018-07-08 08:29:05.401 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/3dl to iray/rssy 3delight to iray.dse
    Post edited by ddyack on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    The libpng warnings are harmless, most of the rest are not warnings or errors as far as i can see but just information. It's the last bit,
    that's the issue. Did you install manaully or using DIM or Connect?
    I used the Daz Install Manager - is it not registered properly?
    Which version of DS is this - Help>About Daz Studio?
    Sorry for delays - had machine issues - this is a new install using the DIM.   I thinkig maybe something in daz is not registered or something.
    644 x 478 - 707K
    Hi Everyone,
    I was able to fix this by installing from within Daz3D by clicking on the grey product box after uninstalling it.
    I am not sure what the problem was but it is fixed now :).
    Thank you for all the feedback here!
  • All I ever get is the genral shader applied, i could have done that through the studio itself, not woth the purchas of the product, we shouldn't have to jump through hoops in this forum or else where to get something to work you have paid for. just not good enopugh from the vendor.
    I don't know if this is doable with this script, but would it be possible to set it up so that a 3dl cutout-based glass is converted so that the cutout transparency is applied as Refraction Weight and Invert image applied?
  • Still rubbish, no matter what i do, it still gives bad results in a render, I personaly think it should be removed from the store. We shouldn't haveto add to scripts or do extra work to get a result. All in all its a poorley produced product.
  • barbultbarbult Posts: 27,479
    If you are dissatisfied, and you purchased the product within the last 30 days, submit a help request and ask for a refund. Your money will be cheerfully refunded, as the saying goes. In your request, be clear that you don't want technical support (if that is truly the case) and the refund will be processed without any hassle at all.
  • Thank you, but its not just about a refund, i have not ask for one and will still not ask for one, its about the product quality for me, I use daz products to make art work like most people on here i think, It seems that this product just keeps adding the basic iray shader to almost everything i do, granted it dos figures, but there are better figure shader than this product, The original post was about mirror shaders, and other people commented on how disappointed they are with this product.  Since buying it i have tried and tried to add shader and scripts to it, but in the end if your not tech savvy on how to do this, then whats the point in trying, why should we spend hrs and hrs trying to add things, make things work on supposedly a ready made solution product.  I suspect there are many people that  have the time to add stuff and are happy with it, My point of view is that its just not good enough , and wanted to add to the other previuos comments about getting rubbish results.
  • jukingeojukingeo Posts: 761
    Good thread!  And also a good thing I popped in here when I searched for how this product works.  It looks like it is a major problem, so off my wishlist it comes.  That is sad that it doesn't work properly.  The thing is that I am seeing posts here from the summer, so this product is not that new.  You figure it would have been fixed by now.  Well, it is now January and the last post was from September, so perhaps it WAS fixed by now, but I am not chancing it.
    The 3DL to Iray converter is certainly not perfect, and often needs tweeking. It's biggest drawback is a lack of a "Make Art" button laugh
    That said, I use it a lot: with older products, and/or 'Poser only' products, and it saves me hours of work by doing the bulk of conversions, and if I need to manually change some surfaces, I'm still ahead.
    I'm a satisfied customer.
    I find this and the reverse script _absolutely_ invaluable and save me a huge amount of work.
    I use both all the time and am a very satisfied customer.
  • SzarkSzark Posts: 10,634
    As per the original request of a Mirror Shader. This is far the best Iray Mirror shader out there http://www.sharecg.com/v/81125/browse/21/DAZ-Studio/Iray-Mirror-Shader
