Geometry shell on Victoria 8 iray problem
Hi,
I'm making a product that needs a shell on Victoria 8 and when I create it and apply materials I get some strange effects when I render it. I've hidden parts of the shell in this sample to point out the issue.
The thing is that when the light source is behind the figure the shell glows red. Which looks like SSS to me but its just copied from V8 so it should look the same...
Can anybody help?![]()
751 x 518 - 218K
Did you convert the Geoshell materials to Iray before you copy-pasted? Creating a blank Geoshell means it has default 3Delight materials, and when you paste an Iray material onto a 3Delight material, the shader is not changed. And when you paste a mismatched shader type, only parameters with the same name will be pasted — anything with a different name or that doesn't exist in 3Delight will be ignored, leading to probable Weird Stuff™ happening when you render.
Yes I did, it is iray.
