Genesis from Poser to Vue
SotoSoto Posts: 1,451
I have a friend wanting to use Genesis from Poser to Vue.
But it seems her UV maps are switching back to default during the transition to Vue.
She is using the M5 maps and indeed looks like the UV switched to V4 causing a mess.
Someone knows the proper way to send your Poser/Genesis scenes to Vue so this doesn't happens?
Thanks!
  • UnseenUnseen Posts: 830
    I have the same problem and I unfortunately have no tip to offer. I hope that someone else knows what to do...
  • RodrakRodrak Posts: 81
    Here is one stupid idea:
    - backup base genesis definition \data\daz 3d\genesis\base\genesis.dsf
    - unpack/edit the file and change default uv set to the one you want. I see line looking like:
    "default_uv_set" : "/data/DAZ 3D/Genesis/Base/UV Sets/DAZ 3D/Base/Victoria 4.dsf#Victoria 4",
    (I have no idea if changing this line is enough)
    - now try to transfer again and hopefully poser changes the uv to new "default" one...
    - restore the original genesis.dsf
    Sorry, I have absolutely no clue if this will work. I don't have Poser or Vue ;-)
