LuxCoreRender ....... is this the same Lux render which has been used with Reality?
BendinggrassBendinggrass Posts: 1,383
And if so, will it still work with Reality?
If it is not the same Lux render, what are the differences?
Thanks.
  • rk66rk66 Posts: 450
    No, LuxCore is all new, look here https://luxcorerender.org/
  • gederixgederix Posts: 392
    Luxcore is the new lux engine currently being developed.
    It is already a part of reality - if you are a Reality user and have reality 4.x then luxcore is used when you select cpu-accelerated for your rendering. If you use cpu-no acceleration then you are using luxrender classic, which is what I use mainly as luxcore, while faster, is still not quite ready for prime time. For me once a scene gets too 'busy' luxcore will just grind to a halt, dragging my machine down with it. Mostly I use luxcore for test renders, simple scenes, even kind of busy scenes, but once I add that one thing too many and luxcore 'eats the after dinner mint' there is no choice but to revert to luxrender.
