Virtually unable to render iray scenes
Hello everyone,
Lately I have been having quite a lot of problems with getting Iray renders to work. Even very simple scenes render extremely slowly, or worse switch to CPU mode. In this case I mean renders such as a floor, two walls, using the Promo Style Catch Lights for Iray, a single chair and two genesis 3 male characters. With simple clothes (bad boy outfit) it already overflowed my GPU memory and switched to CPU. I have a GTX 1070 and a GTX 950. It's understandable that perhaps the 950 can't handle it, but the 1070 should easily be able to render such simple scenes right?
Anyone know why this is happening? The problem persists after closing and reopening Daz.
  • You will probably need to post your log file for a real diagnosis. The description is too vague for me to list a specific reason for your problem. The log will detail the complexity of the the scene, memory allocations, render cards used, failures, etc. I'm sure someone will be able to help with that information.
    This is the log file.
    2018-06-13 21:33:47.595 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
    2018-06-13 21:33:47.685 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 2 device(s):
    2018-06-13 21:33:47.685 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1070)
    2018-06-13 21:33:47.687 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CUDA device 1 (GeForce GTX 750 Ti)
    2018-06-13 21:33:47.687 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-06-13 21:33:47.687 Iray VERBOSE - module:category(IRAY:RENDER):   1.9   IRAY   rend progr: CUDA device 0 (GeForce GTX 1070): Processing scene...
    2018-06-13 21:33:47.688 Iray VERBOSE - module:category(IRAY:RENDER):   1.6   IRAY   rend progr: CUDA device 1 (GeForce GTX 750 Ti): Processing scene...
    2018-06-13 21:33:51.318 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Geometry memory consumption: 93.4621 MiB (device 0), 0 B (host)
    2018-06-13 21:33:51.348 Iray VERBOSE - module:category(IRAY:RENDER):   1.3   IRAY   rend stat : Geometry memory consumption: 93.4621 MiB (device 1), 0 B (host)
    2018-06-13 21:34:42.114 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.3   IRAY   rend error: Unable to allocate 67108864 bytes from 31145984 bytes of available device memory
    2018-06-13 21:34:42.117 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Scene setup failed
    2018-06-13 21:34:42.117 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Device failed while rendering
    2018-06-13 21:34:42.175 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Initializing light hierarchy.
    2018-06-13 21:34:42.175 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Texture memory consumption: 4.37437 GiB (device 0)
    2018-06-13 21:34:42.177 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Light hierarchy initialization took 0.00s
    2018-06-13 21:34:42.178 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Lights memory consumption: 3.31641 KiB (device 0)
    2018-06-13 21:34:42.352 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
    2018-06-13 21:34:42.353 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Materials memory consumption: 247.895 KiB (GPU)
    2018-06-13 21:34:42.521 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Scene processed in 54.833s
    2018-06-13 21:34:42.525 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 84.3753 MiB for frame buffer
    2018-06-13 21:34:42.576 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Allocated 1.65625 GiB of work space (2048k active samples in 0.051s)
    2018-06-13 21:34:42.578 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 0 (GeForce GTX 1070): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2018-06-13 21:34:44.031 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : Allocating 1 layer frame buffer
    2018-06-13 21:35:47.613 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00045 iterations after 119.927s.
    2018-06-13 21:35:47.657 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Available GPU memory has increased since out-of-memory failure. Re-enable CUDA device 1.
    2018-06-13 21:35:49.050 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-06-13 21:35:49.050 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00046 iterations after 121.351s.
    2018-06-13 21:35:49.051 Iray VERBOSE - module:category(IRAY:RENDER):   1.9   IRAY   rend progr: CUDA device 1 (GeForce GTX 750 Ti): Processing scene...
    2018-06-13 21:35:49.054 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend stat : Lights memory consumption: 3.31641 KiB (device 1)
    2018-06-13 21:35:49.092 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 1 (GeForce GTX 750 Ti): Scene processed in 0.043s
    2018-06-13 21:35:49.093 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.093 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 865.793 MiB
    2018-06-13 21:35:49.095 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.095 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 42.1875 MiB
    2018-06-13 21:35:49.095 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.9   IRAY   rend warn : CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 84.3753 MiB for (device) frame buffer, will try allocating smaller (partial) frame buffer
    2018-06-13 21:35:49.097 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.097 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 865.793 MiB
    2018-06-13 21:35:49.099 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 21.0938 MiB
    2018-06-13 21:35:49.099 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.9   IRAY   rend warn : CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 42.1878 MiB for (device) frame buffer, will try allocating smaller (partial) frame buffer
    2018-06-13 21:35:49.099 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.101 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 766.98 MiB
    2018-06-13 21:35:49.103 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.103 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 3.51563 MiB
    2018-06-13 21:35:49.104 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.9   IRAY   rend warn : CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 21.0941 MiB for (device) frame buffer, will try allocating smaller (partial) frame buffer
    2018-06-13 21:35:49.105 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.105 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 408.387 MiB
    2018-06-13 21:35:49.109 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 1 (GeForce GTX 750 Ti): Allocated 10.5472 MiB for device frame buffer
    2018-06-13 21:35:49.142 Iray INFO - module:category(IRAY:RENDER):   1.9   IRAY   rend info : CUDA device 1 (GeForce GTX 750 Ti): Allocated 84.3753 MiB for host-side frame buffer
    2018-06-13 21:35:49.142 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.9   IRAY   rend warn : CUDA device 1 (GeForce GTX 750 Ti): Succeeded in allocating partial device frame buffer. Device efficiency will be affected.
    2018-06-13 21:35:49.145 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.145 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 49.793 MiB
    2018-06-13 21:35:49.145 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): May not have enough memory available to execute CUDA kernel (estimated 49.793 MiB).
    2018-06-13 21:35:49.146 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): out of memory (while allocating memory)
    2018-06-13 21:35:49.146 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to allocate 6.71875 MiB
    2018-06-13 21:35:50.503 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00047 iterations after 122.804s.
    2018-06-13 21:35:51.572 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.4   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Kernel [1] failed after 0.003s
    2018-06-13 21:35:51.572 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while launching CUDA renderer in core_cuda_host.cpp:333)
    2018-06-13 21:35:51.572 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.4   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while launching CUDA renderer in core_renderer_wf.cpp:807)
    2018-06-13 21:35:51.574 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Failed to launch renderer
    2018-06-13 21:35:51.575 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.4   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Failed to launch renderer
    2018-06-13 21:35:51.575 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.577 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): Device failed while rendering
    2018-06-13 21:35:51.577 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): Device failed while rendering
    2018-06-13 21:35:51.577 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.6   IRAY   rend warn : All available GPUs failed.
    2018-06-13 21:35:51.580 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : Falling back to CPU rendering.
    2018-06-13 21:35:51.580 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while initializing memory buffer)
    2018-06-13 21:35:51.580 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.582 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.582 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: All workers failed: aborting render
    2018-06-13 21:35:51.584 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.586 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.587 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.6   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.590 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.591 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.593 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.595 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.9   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.595 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.597 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1070): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.597 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.598 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.599 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 1 (GeForce GTX 750 Ti): unspecified launch failure (while de-allocating memory)
    2018-06-13 21:35:51.605 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 8 cores for rendering
    2018-06-13 21:35:51.607 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
    2018-06-13 21:35:51.607 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU
    2018-06-13 21:35:51.607 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
    2018-06-13 21:35:51.607 Iray VERBOSE - module:category(IRAY:RENDER):   1.6   IRAY   rend progr: CPU: Processing scene...
    2018-06-13 21:35:51.607 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : CPU: Scene processed in 0.000s
    2018-06-13 21:35:51.609 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Native CPU code generated in 3e-007s
    2018-06-13 21:35:51.638 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : CPU: Allocated 84.3753 MiB for frame buffer
    2018-06-13 21:36:04.594 Iray INFO - module:category(IRAY:RENDER):   1.6   IRAY   rend info : Allocating 1 layer frame buffer
    2018-06-13 21:36:04.719 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00048 iterations after 136.995s.
    2018-06-13 21:36:17.427 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00049 iterations after 149.704s.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Something odd is going on with your 750Ti - it fails due to memory, then it tries again, fails again, and after that the 1070 also fails. Try doing a render without enabling the 750 - uncheck it in the Advanced tab of Render Settings - and see how that goes. If it still fails please post the log from that session.
  • Something odd is going on with your 750Ti - it fails due to memory, then it tries again, fails again, and after that the 1070 also fails. Try doing a render without enabling the 750 - uncheck it in the Advanced tab of Render Settings - and see how that goes. If it still fails please post the log from that session.
    Hi, thanks so much, that actually did work. I guess I'll just have to settle for rendering without the 750 from now on. Oddly enough significantly faster in terms of iterations without it as well now.
    @sytze_jorritsma "Oddly enough significantly faster in terms of iterations without it as well now."
    Iray will throttle the faster card to match the slower one.
