Refresh texture
Hello!
I would like to ask if there's a way to make DAZ reload / refresh a texture that I use in the "Surface" tab.
I changed it in an external paint program, and I would like to see the changes immediately.
Currently, the only quick, reliable way for me is to render the image out.
Is there a quicker way?
Thank you very much!
  • Richard HaseltineRichard Haseltine Posts: 111,315
    There should be a reload/refresh command in the Surfaces pane option menu (lined button in the top corner, or right-click the tab) though, at least in the past, people have found it can sometimes get stuck.
  • ForestBoyForestBoy Posts: 76
    Thanks, it works for me!
    One thing that can lock an image is having a render window that used it open (because if the image was updated and you resumed the render it wouldn't match the current state of the model).
    Edit: It works sometimes.
    Sometimes I even have to restart DAZ.
    What a pity that it's unreliable.
