Problem shoulder on Genesis 8 Female
Hello,
It's the twice time i do this work. I have the problem on shoulder when i control arm. Look my screenshots.
Thanks for any help.
1919 x 1015 - 944K
1919 x 1017 - 866K
  • Richard HaseltineRichard Haseltine Posts: 111,475
    The rigging has not been adjusted to take account of the shape - is this a third-party morph or one you made yourself?
  • glyonbalglyonbal Posts: 24
    Thanks for answer. I do no morph. Only buying and install.
  • barbultbarbult Posts: 27,532
    What character are you using? What store did you purchase it from?
    I use Olympia 8 and Marnie, purchased in DAZ and Rendesority.
    I FIND THE PROBLEM !
    The problem is this :
    https://www.daz3d.com/catalog/product/view/id/51269
    If i use a morph of "Big Girl Morphs for Genesis 8 Female", example Evelyn, and i use transform-rotation shoulder/arm and i press "CTRL + Z" for return, it deform this body.
    Do this a few times and it will deform the body even more.
    That seems odd - ctrl-z should restore the status quo ante. It shouldn't matter, but are you sure you are using the Rotate tool or the Universal tool, not the Joint Editor tool?
    Yes, i use Universal Tool. When i use other morph than Big Girl, and i press CTRL+Z, it restore previous shape. If i use morph Big Girl and i press CTRL+Z, it restore previous shape but if i use universale tools or other for rotate-transform arm/shoulder, it deform.
    I did a test:
    I uninstall all files from DIM. I install only Victoria 8 and Body Morphs. In soft DAZ, i load Victoria and i use morph "Heavy", No problem on manipulation.
    Now, if i install "Big Girl Morphs for Genesis 8 Female", and i use morph "heavy" or "BGM ..." with new character, it deform body with this technical: CTRL + Z.
    So, "Big Girl Morphs for Genesis 8 Female" needs a update !
    glyonbal said:
    I did a test:
    Please open a Technical Support ticket, describing the steps you take to trigger the error (as in your post).
    glyonbal said:
    I did a test:
    Before, i'm going to go a video.
    Please make your video without skin textures on Victoria. With skin textures it is "nudity" which is not allowed in these forums.
    Step-by-step instructions are going to be more helpful for support than a video.
    How open  a Technical Support ticket ?
  • SimonJMSimonJM Posts: 6,101
    Go here and fill out the details (you wil probably need to click on the 'login' button in the top right first,)
    Ok, thanks.
