Signature
Curently i dont sign my work, but since im getting better at it i want to start signing my work.
Can you do this automatically in daz or do i need to do it with post work (eg. photoshop)
I know the batch render has that option as an overlay if im not mistaken. Is this a default Daz function?
  • Carola OCarola O Posts: 3,862
    I usually do it in photoshop, don't think Daz Studio has a option for that. Least not that I know of, but I am the first to admit there is much about Daz Studio I don't know :)
    Easiest is to make yourself a png with alpha  that you can just drop on the image in postwork   Is how Daz Promos are done.
  • FishtalesFishtales Posts: 6,244
    That is how I do it but I use IrfanView to place it on the image. I can even do my whole library of pictures using it in batch mode and also rename them and put them in another folder :)
       never though of that, and I use Irfan view for viewing images all the time
  • LeatherGryphonLeatherGryphon Posts: 12,578
    edited June 2018
    I use Photoshop to add a text layer with texture (drop shadow, emboss, etc.) to an image then fade it into the image in an inconspicuous place.  If it's on an oblique wall I change the perspective of the text to make it look as if it's part of the wall.  I'll have one that is easy to see, but I also hide a couple more, more carefully in the image just in case someone erases or cuts out the primary signature.  In which case I can then confront them with the well hidden signatures.
    Another option is, you could make a signature prop, and include it in the scene. That could be as simple as a plane with an image attached, or maybe a text object prop (there are several products in the store for converting text to props, or you could do it in an external modeller), and so on.
  • davesodaveso Posts: 8,389
    whats the deal with digital watermarking?
  • KitsumoKitsumo Posts: 1,222
    That's awesome, so it's like an Easter egg in every image. Didn't Seinfeld do that with his TV show?
