Carrara vs Monoprice driver
I have been using a Monoprice tablet with my Mac for several months. I'm using it in place of an ordinary mouse in ordinary applications. And it works fine. But when I try to use it with Carrara, more often than not, it snaps into a mode in which the tablet touch or lack of touch is detected, but the coordinates always come out as (0, 0) i.e. the upper left-hand corner. And then, even after quitting Carrara, my tablet is still stuck in the upper left-hand corner. At these times, the only way out is to reboot.
Reinstalling the driver did nothing in the moment, only rebooting did anything.
Has anyone else encountered this? Do I need to tell Carrara about my Monoprice tablet in some special way?
I have a monoprice tablet I have used with Carrara on a PC ( not mac ) It worked fine as far as I could tell.
In this case I was using it more as a mouse and didn't really like it, so I stopped. Buton a PC it seemed fine.
( except the scroll function)
8068
In the preferences the is a check box " graphics tablet compatibility mode" ?
I use a Wacom Bamboo, which I really like, but recently It has been failing to load up its drivers and not working. As a final resort I re-installed Vista and it is now fine. Do Applemacs get clogged up or are they perfect? I think I had a conflict of some description.
