Daz crashes when trying to save figure/prop asset
N-RArtsN-RArts Posts: 1,609
edited June 2018 in The Commons
So I made a skirt in Daz using the "How to use dForce" thread. But when I go to save it as a figure/prop asset, Daz closes itself and gives me an error message.
I managed to save it as a wearable preset. But it only loads in the character that the skirt was modelled on.
Thanks for any help.
Post edited by N-RArts on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    What is the error? To where are you tring to save, is it a folder for which you have write access?
  • N-RArtsN-RArts Posts: 1,609
    It's in a location that I didn't even know existed until the past few days. It's in a library created by Daz in the My Documents folder on my C: drive (all of my Daz stuff has been installed on my D: drive).
    Do you have to have the PostgreSQL CMS installed to save new clothing?
    527 x 506 - 27K
  • AntManAntMan Posts: 2,171
    edited June 2018
    So this is odd, I had the exact same thing, just started today. I even tested it with a single polygon to see if it was a memory issue. I tossed out the p list and even re installed the last build I had on hand. In the end I saved my "My Daz Library" but through away all other files I could find and downloaded a copy from the store manually and installed it. And it works fine.
    Yesterday I saved assets fine this morning it all went sideways. Hoe do you explain two people having the same issue???
    Post edited by AntMan on
    Well, that looks like a Content Managment communication issue so my first question would be what security software you are running.
    Windows Defender and Malware Bytes
    That would make mine a coincidence because I'm on a Mac.
  • I have had this same problem for a while and Daz has been totally useless in solving it.....hope you have better luck
    Could also be option B - permission issues on a folder involved in the process.
    Hey Richard I am not saying it's not, but I corrected pathways on start up in the terminal window and I used disk utility to check for that. All was OK. Still did the crash on the attempt to save asset.
    Have you submitted the crash report?
    No I just tossed everything out and reinstalled from the store. Had to keep moving forward making products.
