Is something wrong with my render settings?
nathan_1a2fc3c3d6nathan_1a2fc3c3d6 Posts: 54
Hi,
I'm rendering a scene with some lighting and the lighting fades out over distance like a light normally would. E.g the further away the light is, the fainter the light is.
However when it gets fainter it gets faint in these blocks and not in a smooth gradient. If you look at the picture hopefully it will make sense.
Many thanks for your help guys! You're constantly awesome!
Nathan
1920 x 1080 - 303K
  • nathan_1a2fc3c3d6nathan_1a2fc3c3d6 Posts: 54
    P.S. Lighting is not finished yet
  • Richard HaseltineRichard Haseltine Posts: 111,972
    The banding looks like a shadow-bias issue - it may be too low, so that surfaces (sometimes) shadow themselves. Try raising the shadow bias a bit (it's an offset, in cm, so don't go overboard or items will seem to float). If you are using depth-mapped shadows switching to ray-traced will probably help - the resolution of DSMs is fixed and is too low for large environments.
  • LycanthropeXLycanthropeX Posts: 2,287
    it helps if you tell us what program you are using. Just for future reference when asking a question, include if you are using Studio, Poser, Carrara, Bryce etc, that way the community can better answer your question. Some times a fix for Studio won't be the same for Poser etc
    anyway, Richard is probably right, so give that a try
  • SzarkSzark Posts: 10,634
    edited July 2013
    If this is Daz Studio I am guessing it could be the shading rate, what is it set to. 1.00? If that is the case drop it down to 0.20.
    Yes it could also be Sahdow Bias. I find a value of 0.10 works for the most part.
    Post edited by Szark on
    Cheers Richard! Yeah I've done it and it's worked pretty well, just gotta make sure once I put the other lights in that it doesn't mess it up! Thanks!
    It's poser and the shading rate is already at 0
    In Poser you can edit the resolution of shadow maps, they are a parameter on the light. That won't affect the banding but it can help the smoothness of shadow edges.
