Morphing Clothes question...
jakibluejakiblue Posts: 7,281
The Morphing Clothes program that you can buy that will inject morphs into an outfit that doesn't have them...I haven't used it in AGES and I've kinda forgotten how to do it. I've read through the manual but I've got a question not addressed there.
Do you actually need Poser so you can load V4, inject all her different morphs, then save the cr2 back to the library, which is the one you LOAD in Morphing Clothes to transfer the morphs? Is it possible to do this without Poser??
  • Richard HaseltineRichard Haseltine Posts: 111,513
    edited July 2013
    DS 4.5 has the CR2 export which should work - load V4, add morphs if you don't add them with Power Loader, File>Export and select CR2 as the format. Though you can use Transfer Active Morphs on V4 within DS.
  • Zev0Zev0 Posts: 7,123
    edited July 2013
    Ye I just hit the transfer active morphs and it's done:) All custom morphs transferred into clothing with one click. No need to re-save a second set of clothes in your library since it does it on the fly.
    Post edited by Zev0 on
    oooooooo i'd forgotten about that Transfer Morphs in DS!!!
    uh, where exactly is it located?
    never mind, found it!
    Thank you Zev0 and Richard! I had completely forgotten about that!! Works like a charm.
    Cool have fun:)
