Parameter Filter
Leonides02Leonides02 Posts: 1,379
Hey Everyone -
Does anybody know of a way to use the parameter filter to not include unchanged values?
I have about 2 million expressions, and I often mix them in the parameter filter. However, it's very diffiicult to find them later to adjust them.
Thanks!
  • lwaveslwaves Posts: 238
    There's an option near the top of that section called 'Currently Used' (or something like that). Click that and it only shows the parameters that you currently have dialled in on your character.
    I think that's what you're after..
  • Leonides02Leonides02 Posts: 1,379
    Really? That is exactly what I'm after, but I don't see that at all.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    I have a render running so I can't show it on other tabs, it should definitely be on the Shaping tab, and I think it should be the same on the Parameters and Posing tabs as well. Do you see anything above the selected item in the window?
    412 x 357 - 62K
    edited June 2018
    Oooohhh. Okay, got it! Thank you both! :D
    Post edited by Leonides02 on
