Translucency Map Issues
Lately while rendering, I've been running into issues with translucency maps. As you'll see, there's a vast difference in color between the torso and the rest of the body which is odd since I'm using the same settings. I tried unplugging the maps and using the diffuse and got similar results. Has anyone else run into any issues like this and is there a solution?
622 x 879 - 997K
  • Richard HaseltineRichard Haseltine Posts: 112,102
    In Surfaces, open the image menu (for diffuse first if the issue remains with that), click the Image Editor entry, and check that the gamma values match between the surfaces.
  • lface8lface8 Posts: 126
    I didn't know that was an option and it appears the gamma was the issue. There are still some seams, but they're not quite as noticeable as the above render. Thank you for the help, it's much appreciated.
