Built in Morph Mirror Tool DAZ 4.10?
FurGamStudioFurGamStudio Posts: 7
edited June 2018 in New Users
Hello,
Does DAZ 4.10 or any other older have a built in morph mirror capability?
I have created a morph using Dformer on a leg and simply want to mirror it onto the other leg.
I looked into Morph Loader Pro but it doesn't seem to make sense to export, morph, then import.
I would expect DAZ to have a mirror tool especially when working with human models.
Thanks!
Joseph
Post edited by FurGamStudio on
  • Hello,
    I would expect DAZ to have a mirror tool. Or do I need to look at Hexagon?
    Thanks!
    Joseph
  • SixDsSixDs Posts: 2,384
    edited June 2018
    There is a Symmetry tool under Edit >Figure.
    Post edited by SixDs on
  • Richard HaseltineRichard Haseltine Posts: 111,949
    That's for posing, it mirrors (or swaps) bone rotations.
    Merged threads.
  • Peter WadePeter Wade Posts: 1,700
    I don't know about mirroring morphs but there is a trick I've used with D-formers that might help.
    For each D-former you are using, create a new D-former. Select the field of your original D-former then edit->copy->copy selected item from the menus. Select the field of your new D-former and select edit->paste->past to selected item(s). Do the same to copy the D-former and the base. Select the field of your new D-former, go to the parameters tab and reverse the sign of the X value, i.e. -x becomes x, x without a - becomes -x. Do the same to the D-former and the base. This gives you a mirrored version of your original D-former.
  • Cool thank you all! I ended up copying (on paper if you can believe it) the various trans/rot/scale values and just created a new morph using those values (mirrored certain values). Next time I will try that script and the other trick.
