Daz 4.10 freezes Win 10 when using Morph Sliders
Using 388.13 Nvidia driver on Win 10 Pro, every 3d application and renderer I use is fine.  But man, every time I move a morph slider in Daz, the system will every 10 seconds or so freeze, then unfreeze, and this pattern repeats over and over, even after closing down Daz.  So I have to re-boot the whole system.  When I use Daz, I use the numeric type-in fields instead, and it works fine.  I can predictably repeat it too, sometimes ity happens right away, other times I was lucky and it worked fine and then later would get screwy.
One time it even froze where it went to Blue Screen 'Machine Check Exception'.
Also, I noticed if I have several apps open (ie Browser), and if I switch back and forth, Daz then will go into a freezing pattern, but it does not repeat like it does when I use the sliders.  Just weird all around.  But just with Daz 4.10, and it happened in the Public build of 4.10 as well I had when I was using Win 7 64.   It works all fine if I just type in the values and stay in the app.  Never happened in 4.9 series of Daz on my machine.
Anyoneone else ever experience stuff like this?
-Regards
    edited June 2018
    Best you can do until DAZ Studio is made more efficient is to
    1) Task Manager -> Details -> DAZ Studio -> Right Clight -> Set Affinity -> and uncheck 2 or even 3 of your CPU cores being used.
    2) Go to DAZ Studio -> P references -> Display Properties -> Interface -> Display optimization -> Best
        Hardware Anti-Aliasing - On
      as it's unlikely you changed them it's probably not a big help to your problem
    Post edited by nonesuch00 on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    That would help reduce the load from multi-thread processes (such as rendering), but I don't think moprh loading is multi-threaded.
    -Regards
    The first time (in a session) that you set a slider to a non-zero value the moprh deltas (the actual changes in position of the vertices) have to be loaded from disc. However, that will happen regardless of how the non-zero value is applied. I suppose it's possible that your security software is kicking in when the drive is accessed and that might be genrating soem kind of conflicting activity, I can't think of many other ways such a simple act could trigger a cascade ending in a blue-screen.
    edited June 2018
    -Regards
    The morph loading itself wouldn't be multi-threaded but the redrawing of the viewport would be I think.
    I just reset my 'Interface' in DS to defaults and restarted and that help a little bit, seems l choose one of the Interface values incorrectly. I only now only use 4 or 8 CPU cores for DS in my DS shortcut on my desktop, The hex code you need for that is hex F Use the windows command shell with this argument
    "EXAMPLE: windows commandshell.exe" /c start "DAZ Studio" /affinity F "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\DAZStudio.exe"
    change the DS executable path to match yours though.
