How to make dForce ignore an item?
Hi!
I've been wondering if there's a way to make for example a dForce dress/cloth ignore/not collide with attached props like tails when simulating?
In my case I usually modify textures and cutout opacity to make "tail holes" in clothing and then I hide the tail during dForce simulation.
This isn't a huge bother but I'm just curious.
Thanks for any help!
Select the item
In Parameters select it and scroll down till you see 'Visible in Simulation; Off is not visible in Simulation.
Similar is available in the surfaces tab; surfaces is where you can make a surface visible or not; or even partially visible which can be helpful; Dynamic Strength of 1, down to 0; no action at all.
It can be useful to have it visible, but not affected.
This all worked perfectly, thank you so much, nicstt! \o/
