Please someone help me.(
hck.dllhck.dll Posts: 0
sorry for bad english
Please Someone can convert this model to 3D Studio Max for , obj or max
http://www.artraiders.com/download_page.php?file_id=339
  • Richard HaseltineRichard Haseltine Posts: 111,301
    That's a character for Victoria 4, which is a product here at DAZ 3D. No one else can supply you with a 3DS version of the model and non-one but Sultermermaid can supply you with variant versions of the character. What you could do, if you purchased it, is load V4 into the free DAZ Studio, apply the character and export as FBX or OBJ).
  • hck.dllhck.dll Posts: 0
    Yeah i understand but i try everythings with Pro Poser and Daz Studio , my problem i can't load model with RuinTime . i want someone for me Convert format :) PLEASE
    Thanks and Regards
    As I said, that is not allowed. What problems are you having loading the content, and is it the base figure or the character that is causing the problems?
    http://img.webme.com/pic/s/steams/25b2.jpg
    there ScreenShoot , i select but '' Victorial DELTAS '' etc. i install that , still not working
    How did you install V4 and Morphs++ (installer, DIM, or manually extracting the zip)?
    You need to load the V4 base figure FIRST, then apply the character presets in that folder.
    Then to send it to 3DSM, either export as FBX or OBJ
    Where i can found this
    V4.2 and the Morphs+++.?
    http://img.webme.com/pic/s/steams/b2525.jpg
    I Have now [ Victoria 4.2 Pro Bundle ] and Daz Studio 4.5 Trial
    i setup , ps_pe069_Victoria4.exe and ps_pe070_V4Morphs.exe. but still not working. where i need Setup this packs?
    my Daz 3D Directory C:\Program Files\DAZ 3D\DAZStudio4
    There isn't a DS 4.5 trial - if you bought the free version from the store you have it, it won't expire.
    By default, DS 4 uses C:\Users\[you]\Documents\DAZ 3D\Studio\My Library for its content, so if you haven't changed the defaults that's where you install V4 to. You will then find the figure in the Content Library pane under Poser Formats>My Library>Figures>DAZ People
