Can't seem to Add empty block or edit timeline?
I have come back to Daz after a couple of weeks. But I can't seem to Add empty block or edit timeline?
When I used it last time I could add a new block and edit key frames? But the options are grey and not working now?
Best regards
Jools
If you mean while using Animate, then you have the full version as a 30 day trial, after that, it reverts to Animate Lite. In order to use these other options, you have to buy the full version. Animate 2 does not belong to DAZ 3D, so they cannot give it away for free.
Does anything else expire. Does Daz itself stop working after a certain time?
Decimator is not included in the free version of DS Pro. If you didn't purchase Pro prior to Feburary of 2012, you will need to purchase a separate license for it.
The dynamic cloth control plugin may or may not have a 30 day time limit (I forget if it's included or not) but it it another plugin that requires a separate purchase.
Both of these are not included due prior licensing agreements with the creators.
Natively DS does not have a shadow catcher so you may also want to invest in PW Catch. It's a plugin that does much more than shadow catch but is also handles this task. It's available separately and in a bundle.
No, the free version is the full version, and never expires. As explained above by icprncss, Animate2 and Decimator are plugins that do not belong to DAZ 3D, so they cannot be included in a giveaway. The Dynamic Clothing Control which is free with DS4.6, is the Basic version. If you feel that you will need the full version of it, then it is a paid for item.
