Changing eyebrow colour
How does one change the colour of the eyebrows of a figure, please? My particular problem currently is Molly G8
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,315
    I don't have that set, but are you using the fibremesh brows over a browless texture (in which case it may be as simple as using the Surfaces pane to chnage the base colour of the brows) or are you using the texture with brows painted on?
  • MJWMJW Posts: 540
    Thanks Richard. I used the browless texture (which is sort of limiting) and have tried the surfaces approach which sort of works, but I wondered whether the usual hair shader methods were available as Molly doesn't seem to have eyebrow shaders.
    I don't know, it depends on how the brows are set up.
  • MJWMJW Posts: 540
    Well thanks for the suggestions. I think I need to manage the surfaces more intelligently.
