Ballet Shoes and Dance wear for G8F
in The Commons
Please, can we have some nice ballet shoes, with beat-up/worn looking texture for G8F as well as some nice dance wear to go with? I've had to give my "dancers" canvas shoes to wear or go barefoot.
https://www.daz3d.com/ballerina-outfit-for-genesis-2-female-s
They work, quite well; autofit them, and chose G2F, but leave the second option as none; it just might work better.
Apply an IRAY shader, and tweak as disired.
Edit: Changed G3F to G2F.
thanks! I never thought to use the G2F shoes. Will have to give these a try until someone comes out with a pair for G8F. Tried the ones for G3F (by Fabiana over at Rendo) and that didn't work out well.
I use Fabiana's from over at Rendo and they work very well for me. The Character is Lara for G8F. The outfit, except the leggings, are from Fabiana's Set. I added dForce to the tutu. There are a few options for the shoes in the parameter tab. I think to make the shoes more pointed or round, they help a lot to fit them nice on G8F feet.
No worries, I'll add another render I've got cooking; testing out a shape, a pose and... No and.
Render done; as you can see, a little pokethrough, but fixable easily enough.
I don't like the lack of depth on the straps - sadly that issue for clothes is common in 3D
awesome replies. Thank you both. I will definitely give these two items another go. Perhaps the issue I encountered with Fabiana's product is the fact that I auto-fitted it (after I changed the ID assignment to G8F) while the character was already in pose. I forgot that to to it while at the "A" pose.
Hello there,
I have the G3F Fabiana The Swan ballet outfit After reading the above I tried:-
Hagar who is very slightly built
Auto fit 'G3'F and 'None'
Went to adjustments;
0-FBMExpandAll -2.0
FK-DelicateFeet 0.33
FK-RoundedPoints 1.00
Then put her into a difficult ballet pose the shoes remained in place just as they do for G3F.
Fabiana made these 'future proof' fair play to her, very well done indeed, three cheers .
J
If you are looking for Pointe Shoes for Genesis 8 my go to is the set from the Urban Ballerina set.
Most Daz assets look brand new. If you want the shoes to look worn https://www.daz3d.com/ptf-grungy-threads can be used sparingly to achieve the effect.
I agree - it would be great to see someone make them with the same attention to detail that some of the other outfits get. In the meantime, you're best to either use decals or customize your own textures to get that worn-look.
