Problems using Recipe Builder and Loader for UHT2
I’m having a number of problems getting this product to work, and I’m hoping someone can help me out.
The biggest problem is that the pop-up window that appears when I run the “Recipe Builder” script is so big that it extends below the bottom of my monitor, and I can’t find any way to resize it.
Any help?
  • LaPartitaLaPartita Posts: 417
    bumping this back up in hopes that someone will see it... Does anyone know how to resize pop-up windows within DAZ? I have similar problems with the scripts in Pd Iray Shader Kit 2 and Pose Blender. I can just manage to get those to fit if I put my laptop into tablet mode, but I can't get the Recipe Builder script high enough to see the "make recipe" button.
    edited June 2018
    What is your screen resolution?
    Resizing windows in DS is like any in Windows, move the cursor to the edge and the cursor should change to allow resizing
    Post edited by Mattymanx on
    I'm using the recommended resolution - 1366x768
    It's odd - I can make the script's pop up window larger, but not smaller. And I can't move it vertically, either - so bumping it up to see the bottom of the window isn't working.
    567 x 768 - 68K
  • carrie58carrie58 Posts: 4,171
    Have you increased the resolution of your monitor?
    That's the highest resolution setting possible.
    edited June 2018
    then temporarily lower it that should allow you to see the bottomof the pop up window
    Post edited by carrie58 on
