Problems With 4.6 Crashing
knightedfelineknightedfeline Posts: 29
I'm running a windows 7 machine, w/ 4gig ram (3.74 usable) and it's 64 bit system.
Whenever I start going into the textures and so forth on the DAZ crashes. When it recovers, it says AMD has recovered.
Could someone tell me what's going on and if I'm better off going back to DAZ 32 bit?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    It's hard to tell from your description, but the reference to AMD Recovering does suggest it may be video card-related (assuming you have an AMD card or chipset). Checking for updated drivers might help.
  • knightedfelineknightedfeline Posts: 29
    Update was the first thing I did to my chipset. Is there anything else that might be causing it or any suggestions?
    UPDATE: This crash seems to be happening every time I use the "Surface Selection Tool" & have the "Surfaces" window open while I'm working on a figure to change something that's wrong about the the textures that are applied. So far I've had this happen 4x on different characters.
