Creating bones and movements in own character
Hello, I'm starting now in Daz Studio, and I have a question. I have a personal character that I modeled in other software, I exported it to the Daz but I would like to know how I add bones and movements in it, what tool is used, is it possible in daz? thank you.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    There are two methods, though both are easier if the imported mesh has groups for the bones. You can import the geometry into the Figure Setup pane, by right-click in the listing panel on the left, then drag it into the Relationships panel on the right, rearrange the hierarchy, change rotation order by right-click, and create a basic figure from that or you can import the model into the viewport via File>Import, convert to a single bone figure via Edit>Object>Rigging then use the Joint Editor tool's right-click menu to add bones on the fly. Once you have a basic figure by either route you use the Joint Editor to set the bone positions, then the Geometry Editor and Node Weight Paint Brush to edit the bending.
