How do you make the HDRI distant without having to use camera and distort?
Richard John S
Does anyone know how make the HDRI distant without having to use focus length or frame width in the camera settings which give you that fish eye look? I bought the Scifi HDRIs and when loading the stars just appear so close to the figure. I want to push the HDRI back so that the figure remains the same for close shot portrait without the fish eye distortion when using the camera, and I want the stard to be more distant rather than close.
In the Environment tab of the Render pane, you can check "Environment Blur".
But if you're getting fish-eye with your camera and don't want it, why do you not want to change the focal length (and focal distance of course)?
I tried the environmental blue but it doesn't seem to do anything. The only way I can seem to get the HDRI to make the stars distant is to use the camea and use the focal lenght, but when I set it enough to make the stars distant is when I get the fish eye view.
Instead of adjusting the focal length to make the stars blur, try adjusting the f/stop (aperture). Set your focal length to give you the composition you want, then adjust the f/stop to get the desired depth of field. You can see the two planes converge to either side of the focal point.
