NULL script error for Fishtail Braids for Genesis
MouserMouser Posts: 775
Hi, not sure what's wrong but I as usual copied the content directories (data, People & Runtime) to my Poser Pro 2012 Content directory.
But when I try to load the Fishtail Braids in Poser 2012pro I get a NUL or empty script error?
I've checked 3 times and I have copied all of the content files to the correct location.
I've done this before with other zipped content from DAZ without issue, it just seems to be the Fishtail Braids for Genesis that doesn't work?
Any ideas as to the cause?
  • Richard HaseltineRichard Haseltine Posts: 111,637
    You should have a Poser file (HR2 or CR2), a .py file, a .duf file and a PNG image all with the same name - do you?
  • MouserMouser Posts: 775
    Well the fishtail braids for the mil4 figures works but not genesis?
    Not sure what make of this, may have to download again just in case.
    The fourth generation braids don't need the scripts. You do have the DSON Importer installed, I assume? Genesis itself is loading?
    Yes the DSON converter is installed, I have a number of other Genesis figures installed without a problem.
    It just the Genesis Fishtail hair that's giving grief.
    Unless anyone else has some ideas I think you need to open a support ticket. Sorry I can't be more helpful.
