Missing something when trying to subclass DzExporter - what is it?
Hello,
I am trying to create an exporter plugin by subclassing DzExporter but am receiving the error C2259 'cannot instantiate abstract class' when I try to compile.
I have overridden all the pure virtual methods that are defined in DzExporter and cannot see what else to do as the compiler provides no more information.
If I define a class
class MyQObject : public QObject {
Q_OBJECT
public:
MyQObject() {}
};and give this to the DZ_PLUGIN_CLASS_GUID() macro, the project builds fine, so the issue must be somewhere in the hierarchy of classes that my exporter sits in.
Here is my exporter
class MyDazExporter : public DzExporter {
Q_OBJECT
public:
/** Constructor **/
MyDazExporter() : DzExporter(QString("ext")) { }
public slots:
virtual QString getDescription() const { return QString("hello"); };
virtual bool isFileExporter() const { return true; };
protected:
virtual DzError write( const QString &filename;, const DzFileIOSettings *options ) const { return 0; };
};The DzExporter is defined
class DZ_EXPORT DzExporter : public DzFileIO {
Q_OBJECT
public:
DzExporter( const QString &extension; );
virtual ~DzExporter();
public slots:
DzError writeFile( const QString &filename; );
DzError writeFile( const QString &filename;, const DzFileIOSettings *options );
QString getExtension() const { return m_extension; }
virtual QString getDescription() const = 0;
virtual bool isFileExporter() const = 0;
protected:
virtual DzError write( const QString &filename;, const DzFileIOSettings *options ) = 0;
private:
QString m_extension;
};If I copy my class into one of the example projects I get the same result.
What else do I have to do?
When I try compiling your code I get the following:
..\recentfilesaction.cpp(53) : error C2259: 'MyDazExporter' : cannot instantiate abstract class
due to following members:
'void DzFileIO::getDefaultOptions(DzFileIOSettings *) const' : is abstract
e:\work\dazstudio\sdk4.5\include\dzfileio.h(81) : see declaration of 'DzFileIO::getDefaultOptions'
'DzError DzExporter::write(const QString &,const DzFileIOSettings *)' : is abstract
E:\Work\DazStudio\sdk4.5\include\dzexporter.h(76) : see declaration of 'DzExporter::write'
Which means you have to also provide an implementation of getDefaultOptions
Also write isn't a const, you need to drop that const.
This compiles for me (assuming you stick the class in a header file that is ran through the MOC process.
Hi msorrels,
Thank you very much, that was it!
SJ
