G3F shape imported for G8F, now clothes don't fit properly
A bit more clarification:
I used someone's tutorial on how to get G3F morphs over to G8F and it worked, sort of. While using my custom morphs from G3F on G8F, it visually does make G8 look like G3 does, but for some reason it's only visually. Whenever I load clothes onto said G8 (for which only the custom morph is enabled at any %) all of those clothing items act as if no morphs are in use, even with mesh smoothing modifier. So if I want to use any clothes
I'm guessing there's more to morphs than just the morph files, right?
Might be worth mentioning the morphs only appears if I load it onto the model. After a fresh reboot of DS and loading a new G8F the morphs is gone from selection.
3000 x 3840 - 4M
  • barbultbarbult Posts: 27,442
    The morphs probably need to have auto follow turned in in their parameters. If you want the morph to be available the next time you run DS, you need to save it as a morph asset.
  • Saved the morph asset(s) and now it's working. Many thanks, Barbult.
