Studio suddenly started crashing
SylvanSylvan Posts: 2,719
I've never really had any poblems with crashes in the past years using DS, but since a week or two, it keeps crashing every 10 minutes or so. The warnings I'm getting from the bug report are:
WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Male
And:
WARNING: libpng warning: iCCP: known incorrect sRGB profile
WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
What is happening here? My savefiles load fine, so it doesn't seem like anything is missing.
Post edited by Sylvan on
  • SylvanSylvan Posts: 2,719
    And it's getting worse now :O
    Saved scenes are start to getting corrupt and items dissapear from where I placed them. Nooo!
  • Richard HaseltineRichard Haseltine Posts: 111,325
    The libpng you can ignore. The output property errors are also likely to be safe - connections for adjustments where you simply don't have the thing being adjusted for. If it's just started the obvious suspects are updated drivers or security software, or other utilities, malware, heat (if the weather has just changed), or other incipient hardware issue.
  • barbultbarbult Posts: 27,474
    Hard disc failing?
    barbult said:
    Hard disc failing?
    Uh, I hope not. But it's an old one, so might be Oo Didn't cross my mind, I'm going to take precautions right away, thanks for the headsup!
  • Kev914Kev914 Posts: 1,143
    If it's a standard drive, they typically make noises when they are failing. Mine would make a little tick, tick sound and then the system would just reboot.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    OK, so my Daz has started randomly crashing today.  No warning, just shut down on it's own.  It did it just now even though I wasn't doing anything - I was browsing the web at the time, and Studio had been sitting more or less idle for 15 minutes with no input from me whatsoever.
    It crashed earlier in the day when I was posing some figures as well.
    New SSD, so it's not a hard drive failure issue.
