Problem after reinstalling / moving library
Okay. So, I have a character, which I've worked on multiple times and saved in multiple scenes. Unfortunately, I had an issue with size limits on my DAZ-drive, so I moved the library - that didn't go quite as well as planned, due to a failed drive in a RAID-setup, so I decided to just "start over" - reset the database, reinstalled everything via DIM, and reassigned links in DAZ to point to the new locations. All that seems to be working more or less fine. However, I have an issue with the character (which is based on Teen Josie 7 for Teen Josie 8 / Genesis 8 Female).
I've attached files for both the previous look, and the in-DAZ-look of the character now
Anyone have any idea what is causing this? No warnings on scene-load, all assets (that I can think of) is present (installed via DIM, also tried reinstalling them, and loading the scene when they were not installed - then DAZ complained about missing files). So it seems the assets are present, they're just not applied, for some reason.
There are no errors in the logs, just some warnings about "Could not find output property" (and then the body, head-morphs for G8F, and a breast mod. I've attached everything that's logged when opening the scene.
2018-05-28 14:52:42.648 *** Scene Cleared ***2018-05-28 14:52:43.033 *** Scene Cleared ***2018-05-28 14:52:46.820 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.820 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.824 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.824 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.824 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.824 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.825 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.825 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.825 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.829 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.833 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.837 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.837 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.837 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.837 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.837 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.838 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.838 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:46.841 JSON interpreter warning: Unexpected numeric member: version2018-05-28 14:52:46.841 JSON interpreter warning: Unexpected string member: type2018-05-28 14:52:48.288 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Soto/Breast%20Utilities/PBMAreolaDiameterR.dsf#Areola%20Diameter%20R?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Soto/Breast%20Utilities/PBMAreolaDiameter.dsf#PBMAreolaDiameter2018-05-28 14:52:48.292 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/Soto/Breast%20Utilities/PBMAreolaDiameterL.dsf#Areola%20Diameter%20L?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Soto/Breast%20Utilities/PBMAreolaDiameter.dsf#PBMAreolaDiameter2018-05-28 14:52:48.295 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLMouthSmileSimpleR.dsf#eCTRLMouthSmileSimpleR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLMouthSmileSimple.dsf#eCTRLMouthSmileSimple2018-05-28 14:52:48.299 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLMouthSmileSimpleL.dsf#eCTRLMouthSmileSimpleL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLMouthSmileSimple.dsf#eCTRLMouthSmileSimple2018-05-28 14:52:48.303 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipTopOut-InR.dsf#eCTRLLipTopOut-InR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipTopOut-In.dsf#eCTRLLipTopOut-In2018-05-28 14:52:48.307 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipTopOut-InL.dsf#eCTRLLipTopOut-InL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipTopOut-In.dsf#eCTRLLipTopOut-In2018-05-28 14:52:48.308 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomUp-DownR.dsf#eCTRLLipBottomUp-DownR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomUp-Down.dsf#eCTRLLipBottomUp-Down2018-05-28 14:52:48.313 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomUp-DownL.dsf#eCTRLLipBottomUp-DownL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomUp-Down.dsf#eCTRLLipBottomUp-Down2018-05-28 14:52:48.313 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomOut-InR.dsf#eCTRLLipBottomOut-InR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomOut-In.dsf#eCTRLLipBottomOut-In2018-05-28 14:52:48.317 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomOut-InL.dsf#eCTRLLipBottomOut-InL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLLipBottomOut-In.dsf#eCTRLLipBottomOut-In2018-05-28 14:52:48.317 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyesClosedR.dsf#ECTRLEyesClosedR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyesClosed.dsf#ECTRLEyesClosed2018-05-28 14:52:48.320 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyesClosedL.dsf#ECTRLEyesClosedL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyesClosed.dsf#ECTRLEyesClosed2018-05-28 14:52:48.320 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyelidsLowerUpDownR.dsf#ECTRLEyelidsLowerUpDownR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyelidsLowerUpDown.dsf#ECTRLEyelidsLowerUpDown2018-05-28 14:52:48.324 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyelidsLowerUpDownL.dsf#ECTRLEyelidsLowerUpDownL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLEyelidsLowerUpDown.dsf#ECTRLEyelidsLowerUpDown2018-05-28 14:52:48.324 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowUp-DownR.dsf#eCTRLBrowUp-DownR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowUp-Down.dsf#eCTRLBrowUp-Down2018-05-28 14:52:48.328 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowUp-DownL.dsf#eCTRLBrowUp-DownL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowUp-Down.dsf#eCTRLBrowUp-Down2018-05-28 14:52:48.328 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowInnerUp-DownR.dsf#eCTRLBrowInnerUp-DownR?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowInnerUp-Down.dsf#eCTRLBrowInnerUp-Down2018-05-28 14:52:48.332 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowInnerUp-DownL.dsf#eCTRLBrowInnerUp-DownL?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLBrowInnerUp-Down.dsf#eCTRLBrowInnerUp-Down2018-05-28 14:52:48.332 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Teen%20Josie%207/FHMJosie7Head.dsf#FHMJosie7Head?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Teen%20Josie%207/CTRLJosie7.dsf#CTRLJosie72018-05-28 14:52:48.336 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Teen%20Josie%207/FBMJosie7Body.dsf#FBMJosie7Body?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Teen%20Josie%207/CTRLJosie7.dsf#CTRLJosie72018-05-28 14:52:48.606 File loaded in 0 min 5.7 sec.2018-05-28 14:52:48.611 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.611 Loaded file: Iris Concave.dsf2018-05-28 14:52:48.613 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.639 Loaded file: PHMEyelashesLengthUpper.dsf2018-05-28 14:52:48.640 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.640 Loaded file: PHMEyelashesLengthLower.dsf2018-05-28 14:52:48.642 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.642 Loaded file: PHMEyelashesCurl.dsf2018-05-28 14:52:48.644 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.644 Loaded file: Aisling_EyeRealism.dsf2018-05-28 14:52:48.646 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.646 Loaded file: PHMEyesPupilsDilate.dsf2018-05-28 14:52:48.653 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.653 Loaded file: PHMEyesCorneaBulge.dsf2018-05-28 14:52:48.654 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.654 Loaded file: PBMAreolaDiameter.dsf2018-05-28 14:52:48.658 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.658 Loaded file: buttocks out.dsf2018-05-28 14:52:48.661 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.661 Loaded file: buttocks massive.dsf2018-05-28 14:52:48.663 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.669 Loaded file: PBMNipplesSize.dsf2018-05-28 14:52:48.672 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.672 Loaded file: PBMBreastsSize.dsf2018-05-28 14:52:48.674 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.674 Loaded file: PBMBreastsDiameter.dsf2018-05-28 14:52:48.677 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.677 Loaded file: PBMBreastsCleavage.dsf2018-05-28 14:52:48.679 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.679 Loaded file: PBMAreolaeDiameter.dsf2018-05-28 14:52:48.686 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.686 Loaded file: PBMNipples.dsf2018-05-28 14:52:48.698 Loaded file: jules_jeans_p1_ahead_eo.duf2018-05-28 14:52:48.876 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.876 Loaded file: PHMMouthRealism_HD_div2.dsf2018-05-28 14:52:48.881 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.881 Loaded file: PBMNavel.dsf2018-05-28 14:52:48.988 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:48.988 Loaded file: Left Behind Shoulder.dsf2018-05-28 14:52:49.156 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.156 Loaded file: Adjust-Chest.dsf2018-05-28 14:52:49.158 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.158 Loaded file: Adjust-BreastR.dsf2018-05-28 14:52:49.160 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.160 Loaded file: Adjust-BreastL.dsf2018-05-28 14:52:49.569 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.569 Loaded file: Fix.dsf2018-05-28 14:52:49.723 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.728 Loaded file: Adj Front Waistband.dsf2018-05-28 14:52:49.729 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.729 Loaded file: Adj Back Waistband.dsf2018-05-28 14:52:49.730 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.730 Loaded file: lbjeans.dsf2018-05-28 14:52:49.868 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:49.868 Loaded file: lbshoes.dsf2018-05-28 14:52:50.007 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:50.008 Loaded file: Fit-OverPants.dsf2018-05-28 14:52:50.015 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:50.015 Loaded file: Adjust-BreastsOut.dsf2018-05-28 14:52:50.486 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:50.486 Loaded file: Adj Toes R.dsf2018-05-28 14:52:50.487 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:50.487 Loaded file: Adj Toes L.dsf2018-05-28 14:52:50.497 Loaded Morph Deltas in 0 min 0.0 sec.2018-05-28 14:52:50.497 Loaded file: Boots.dsf2018-05-28 14:52:50.604 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.609 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.617 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.640 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.642 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.671 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:50.962 Loaded image Victoria8GensD.jpg2018-05-28 14:52:51.311 Loaded image Victoria8LegsD_1003.jpg2018-05-28 14:52:51.399 Loaded image Victoria8Eyes02D_1006.jpg2018-05-28 14:52:51.664 Loaded image Victoria8ArmsD_1004.jpg2018-05-28 14:52:51.747 Loaded image Victoria8MouthD_1005.jpg2018-05-28 14:52:51.977 Loaded image Victoria8FaceD_1001.jpg2018-05-28 14:52:52.209 Loaded image Victoria8TorsoD_1002.jpg2018-05-28 14:52:52.235 Loaded image Fiber_Strand_Dif_00.jpg2018-05-28 14:52:52.534 Loaded image 1LB_Jeans.jpg2018-05-28 14:52:52.801 Loaded image 1LB_Shoes.jpg2018-05-28 14:52:52.952 Loaded image 05_IndispensableG8MWShortSleeveShirt.jpg2018-05-28 14:52:53.100 Loaded image 01_IndispensableG8MWShortSleeveShirtB.jpg2018-05-28 14:52:53.165 Loaded image Victoria8Eyelashes_1001.jpg2018-05-28 14:52:53.385 Loaded image aprblth_txwhite.jpg2018-05-28 14:52:53.621 Loaded image aprblth_trans.jpg2018-05-28 14:52:55.554 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:55.560 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:52:55.613 WARNING: general\dzmorphdeltas.cpp(342): Invalid vert count specified in DzMorphDeltas::setTargetVertexCount()2018-05-28 14:57:48.977 Loaded image PBMAreolaDiameter.png2018-05-28 14:57:48.978 Loaded image PBMAreolaDiameter.png2018-05-28 14:57:48.984 Loaded image PBMAreolaDiameter.png2018-05-28 14:57:48.985 Loaded image PBMAreolaDiameter.png2018-05-28 15:01:16.855 Loaded image PBMAreolaDiameter.png2018-05-28 15:01:16.861 Loaded image PBMAreolaDiameter.png2018-05-28 15:06:32.175 Loaded image PBMAreolaDiameter.png2018-05-28 15:06:32.176 Loaded image PBMAreolaDiameter.png2018-05-28 15:06:53.330 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-05-28 15:07:18.786 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-05-28 15:07:18.787 WARNING: libpng warning: iCCP: known incorrect sRGB profile2018-05-28 15:08:54.841 Loaded image PBMAreolaDiameter.png2018-05-28 15:08:54.842 Loaded image PBMAreolaDiameter.png
Anyone have any idea what causes this, and what I can do to fix it?
1920 x 1080 - 455K
416 x 927 - 347K
  • Richard HaseltineRichard Haseltine Posts: 111,217
    The unexpected member messages at the beginning may indicate that some files are damaged - that would then explain why the formulas weren't resolving. However, my suggested fix would have been uninstal/reinstall and it sounds as if you have already tried that.
