DAZ Ztudio 4.6 problems with custom morphs
Hi, I've just started playing around with DAZ Studio the genesis2 figure, after creating a couple of custom morphs in zbrush via the GoZ plugin on reopening the file the next day all I see is a figure made of grey boxes, zbrush dials gone, along with all the other actor parameters... any way to recover or I'll have to start from scratch ?
thanks
    Where is your content installed, and where did you save the morph?
  • edited July 2013
    content is installed in the default location and the morph came with GoZ, all with default settings, I just simply saved the file and when I reopened it didn't work anymore. Other files that I did custom morphs the same way work fine though.
    Post edited by maxx10_8a93081532 on
  • Richard HaseltineRichard Haseltine Posts: 111,467
    edited July 2013
    How did you save - as a scene, or as a Morph Asset? And which default location - the one used by DAZ Studio or the one used by the Install Manager?
  • edited December 1969
    saved it as a scene coz it was just a one off situation, a quick "correction" done in zbrush, as for the location it's the default one used by DAZ Studio and the DAZ content installers, never used the install manager
  • BejaymacBejaymac Posts: 2,007
    Sounds like the morph deltas weren't saved with the scene, but are still being referenced by the DUF file, which is why you see grey blocks instead of a figure.
    Any morph you make for a Tri-Ax figure (Genesis, G2F, Dawn etc) needs to be done as a "hard copy" by using "File > Save as > Support asset > Morph Asset", otherwise you will lose it and have to start over.
    will keep that in mind for the future ;)
