How to calculate a coupon payment?
clevelendclevelend Posts: 0
    If you mean how to use coupons, then you simply click the 'apply coupons' option when it asks for your payment type. If you mean how to work out the total cost, then I'd suggest a good calculator.
    If the coupon is one of the spend this much and get this much off, read the email or whatever you were sent the code in to see if it has any limitations. Some coupons can only be used on DAZ Originals, some do not apply to items that have been in the store less than sixty days. Or can't be used on PC or Value items.
    Once you know those things, place the items in your cart and make sure the total is at or exceeds the required spending amount. Input the coupon code and hit apply coupon. Hopefully, you haven't missed anything and the coupon will apply as it's supposed to.
    If it's the monthly PC coupon, it only works on DAZ Originals that aren't PC or Value items.
    Unlike vouchers, coupons cannot be stacked and they are usually a once only, use it all or lose what you don't kind of thing.
