How to reduce texture blockiness?
niallbeirneniallbeirne Posts: 0
When rendering a scene with uberenvironment2 lgiht the skin textures etc. look very blocky. i notice you can reduce it by increasing the occlusion samples but there' still noticable blocks on the textures.
How do you get it so it looks smooth?
  • JaderailJaderail Posts: 0
    edited July 2013
    Check your Render settings, Pixel Samples apply also. And the Shading rate, I run about X 16 Y 16 and Never higher than .5 for Shading rate when I use Uber. Your render time WILL increase.
    Post edited by Jaderail on
  • niallbeirneniallbeirne Posts: 0
    Thanks that's improved it a bit but like you say the render time is now terrible.
    is Daz ever going to use the GPU to do this stuff?
  • VanguardVanguard Posts: 505
    When using UE2 make sure to use the quality setting for UE as well. By default it is set to the lowest value.
