Syntax error - expected '{' or '['
Hello, I purchased and downloaded https://www.daz3d.com/nylyssa-for-genesis-3-and-8-female and no matter how how I try to install...it does not work.
There are no thumbnails and I get the 'error reading file check log'...so I check the log and get the following:
.......Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_51979/people/genesis 8 female/characters/nylyssa.duf (1,1): Syntax error - expected '{' or '['
This is the only item having an issue (everything else has always installed and word...even others I bought with this) and I tried this on a different computer and it worked fine. Something appears to have gotten corrupt during the original install.
Any ideas? I've tried uninstalling, deleting the local folder after, rebooting...redownloading and installing thru DIM...installing manually with fresh download through DIM and once tried inside of DS.
I'm out of ideas. :(
  • Richard HaseltineRichard Haseltine Posts: 112,099
    it does sound like corrupt files. Try a direct download from your Prodct Library page, then check the ehalth of the zip (using a tool like 7Zip). Other people have been using this character, so I'd think the files were healthy at the Daz end (unless there's been a bad update).
  • ironsiteironsite Posts: 11
    I am experiencing this exact same issue. The product was not avaialabe of me via Daz Connect until days after I bought it, and now I am have the same issues as nirvanead. I have tried uninstalling; re-installing; uninstalling again when that didn't work; and using the daz connect offline package download and install. They all result in the same error.
    Does a DIM install work, if you uninstall the Connect version?
