List of changed parameters
3dOutlaw3dOutlaw Posts: 2,481
If I have a figure that I have at the "zero" pose, just loaded...then I start changing things, like translations, rotations, scale, poses (of various body parts)...is there a way to get a list of everything that is not at the default? (or that is changed from the default)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,568
    I guess scroll through them all and write them down not the answer you seek!
    you could save a duf preset I suppose and open it in notepad?
  • Testing6790Testing6790 Posts: 1,091
    Going beyond what wendy suggested, you could make a script that could diff the two and return the non defaults. Wouldn't be insanely hard.
    Yea, there is not too many of them. I will go for the ol' pen and paper route. Thanks!
    edited July 2013
    It's much simpler than a pen and paper.
    If you're talking about DS, select the item (or ctrl click for multiple, works on body parts too) and in the Parameters tab select Currently Used at the top.
    The screenshot was for something else, but it demonstrates what I"m talking about.
    1920 x 1050 - 361K
    Post edited by Lissa_xyz on
    OK, thanks, but unfortunately that only shows the poses (and morphs?). I was looking for translations, rotation, scaling, as well across all parts.
    edited July 2013
    "Currently used" compare with the value which "Memorized figure"
    if you have not "memorized figure" after loding your figure,
    it keep default value of properties about each node.
    So that "Currently used" can show you all changed properties.(but you need to select the node.
    it can only show you properties which assigned to the selection node.
    or if you select multi node at same time, it shows you X-sclae(3) etc.
    it means three nodes X scale have been changed.
    If you want to check all changed properties, you may better check on "show hidden properties", and
    work in parameter tab.
    it can show you all changed properties which you have tweaked.
    (but it show you ERC changed value which you have not directly tweaked too )
    998 x 599 - 111K
    Post edited by kitakoredaz on
