Rendering has super bright light even though I have no lights and Autolamp is turned off.
In render settings I have Autolamp turned off and when I render with no lights it has this extremely bright light from the front/right side that turns some parts completely white from how bright it is. Additionally, when I add in extra lighting the canvas gets brighter but in render the brightness remains the same.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Iray? By default the RuinsHDR environment light is on, you can turn it off in Render Settings under environment by setting the Environment Mode to Scene Only - but since scene lights tend to be relatively dim you will then need to adjust the Tone Mapping settings to compensate (and your renders may take longer to converge).
  • winduptoywinduptoy Posts: 59
    (Also a newbie so maybe not very helpful).  There are several sources of light.  The lights in your scene are one, the Autolamp is another.  And a third is the environment light.  Go to Render > Editor tab and all the way at the bottom is "Environment"
    Fist thing to check is the top:  Environment Mode- you can have the dome on, ot just your studio lights or a combination.  Next thing is Environment intensity.  Try pulling that down and see if it helps.
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2018
    n.m. got something wrong
    Post edited by BeeMKay on
