Errors Loading "H&C Business Suit for Genesis 8 Male(s)"
I bought H&C Business Suit for Genesis 8 Male(s). However, when I try and dress my Genisis 8 Male with certain articles of clothing, I get the attached message—followed by the mountain of errors you can see following the screenshot (and that's only some of them... too many to share). I have the most updated version of DAZStudio and am running on a MacBook Pro with High Sierra (v10.13.4).
I've restarted the computer and DAZStudio. I've uninstalled and reinstalled the clothes. I've done a lot of wishful thinking and hoping. Nothing's working, not even the wishful thinking.
Help, please. This is beyond my skill level, and I'm a bit of a newbie. So please don't be afraid to explain it to me like I'm five.
2018-05-13 13:28:50.426 Error writing author data!
2018-05-13 13:28:50.448 Iray INFO - module:category(API:MISC):   0.0   API    misc info : Loaded "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/libneuray.so"
2018-05-13 13:28:50.449 Iray INFO - module:category(API:MISC):   0.0   API    misc info : Iray 2017.0.1, build 287000.7672, 23 May 2017, macosx-x86-64-clang
2018-05-13 13:28:50.449 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(403): Could not add path: "/Users/michael/Library/Application Support/DAZ 3D/Studio4/shaders/iray". Due to unkown error -2
2018-05-13 13:28:50.449 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(403): Could not add path: "/Users/michael/Library/Application Support/DAZ 3D/Studio4/temp/shaders/iray". Due to unkown error -2
2018-05-13 13:28:50.450 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(CUDA:RENDER):   0.0   CUDA   rend warn : CUDA module initialization failed.
2018-05-13 13:28:50.450 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(CUDA:RENDER):   0.0   CUDA   rend warn : The version of your CUDA driver is 0.0, but 8.0 is the required minimum
2018-05-13 13:28:50.450 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(CUDA:RENDER):   0.0   CUDA   rend warn : Please update your display driver (current version ).
2018-05-13 13:28:50.460 Iray INFO - module:category(PLUG:PLUGIN):   0.0   PLUG   plug info : Loaded library "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/axf_importer.so".
2018-05-13 13:28:50.466 Iray INFO - module:category(PLUG:PLUGIN):   0.0   PLUG   plug info : Loaded library "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/blend_render.so".
2018-05-13 13:28:50.474 Iray INFO - module:category(PLUG:PLUGIN):   0.0   PLUG   plug info : Loaded library "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/cb_importer.so".
2018-05-13 13:28:50.480 Iray INFO - module:category(PLUG:PLUGIN):   0.0   PLUG   plug info : Loaded library "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/ct.so".
2018-05-13 13:28:50.488 Iray INFO - module:category(PLUG:PLUGIN):   0.0   PLUG   plug info : Loaded library "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/dds.so".
2018-05-13 13:28:50.490 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(LINK:PLUGIN):   0.0   LINK   plug warn : Loading /Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/ffmpeg_video_decoder.so: dlopen(/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/ffmpeg_video_decoder.so, 1): Library not loaded: @executable_path/libavutil.54.dylib
2018-05-13 13:28:50.490 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(LINK:PLUGIN):   0.0   LINK   plug warn :   Referenced from: /Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/libavcodec.56.dylib
2018-05-13 13:28:50.490 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(LINK:PLUGIN):   0.0   LINK   plug warn :   Reason: image not found
532 x 239 - 21K
  • Richard HaseltineRichard Haseltine Posts: 111,859
    The error is often caused by trying to load a preset with nothing selected in the scene. The errors from the log look like folder permission errors - having run Daz Studio, or DIM, as administrator can cause those.
  • TotteTotte Posts: 15,219
    The errors in the log does not actually seems to correspond to the error (as you often just see, in the log for these kind of errors, that Richard descibed), "See logfile for more information" ;-)
  • The error is often caused by trying to load a preset with nothing selected in the scene. The errors from the log look like folder permission errors - having run Daz Studio, or DIM, as administrator can cause those.
    Thank you for your help. How do I fix this, then? Create another user on my Mac and install the program under that user? Regardless, this seems like a flaw with the program's design. Maybe? I dunno.
    I wish that the log was more helpful to finding a solution for people who aren't into the nitty gritty on what's going on under the hood ot he program.
    And apologies for posting my previous comment twice. I didn't realize that all comments have to be approved as well. Thank you for newbie patience.
    Not sure my first comment posted. So redoing. Essentially my question was how to fix this? Do I create a new user account and install the program there?
