Removing a shadow
Sorry if this has been asked before, but: is there a way to make an object not cast a shadow when using IRay?
It's surely an essential feature when rendering vampires. smiley
  • Richard HaseltineRichard Haseltine Posts: 111,958
    Not using the standard Photoreal mode. It is possible with Interactive mode, but that is not without its downsides (it disables emissive surfaces, for one). Two renders is probably the best option.
  • cm152335cm152335 Posts: 421
    some usefull tips:
    put emssive plane or spot back of the charactere to break the shadow
    shadow in ground, in render setting, disable "auto ground" and place manualy a ground away from vampires
  • Thanks for the suggestions.
  • Cris PalominoCris Palomino Posts: 13,050
    Iray Canvases.
