Daz Iray Shaders and Lights [project]
astucemanastuceman Posts: 13
edited May 2018 in Freebies
Hi
Are you working with Daz and Iray ?
If yes read little more (that will be interesting for sure)
I am working on that project : https://github.com/Astuceman/Daz-Iray-Shaders-and-Lights
And you allready know github for hosting open source project
So I have created a repo where I have uploaded all of my custom shaders lights and texture where anyone can download, use and improve at anytime for any condition and for free
Check out and have fun
512 x 512 - 390K
512 x 512 - 368K
Post edited by astuceman on
  • nonesuch00nonesuch00 Posts: 18,897
    thanks very much
  • SixDsSixDs Posts: 2,384
    edited May 2018
    Thank you, Astuceman.
    Edit: Yoiks, didn't realize the .zip was that big. For anyone bandwidth challenged, it is about a 750 MB download.
    Post edited by SixDs on
  • Tim NTim N Posts: 193
    edited May 2018
    These are wonderful lights and shaders. Thank you!
    A small note: The test scene loads with the Environment Mode set to Sun-Sky Only. It should probably load as Scene Only.
    Edit: Also, the folder "Shaders Presets" should be renamed "Shader Presets".
    Post edited by Tim N on
  • DigiDotzDigiDotz Posts: 515
    Thanks astuceman! ;-)
  • astucemanastuceman Posts: 13
    Thanks you for your kind words =)
    I have update the folder name
    Maybe you can submit a second file without ?
    I remember that basic light parameter has to be the simplest for my need
