Help needed with The Fantastic Library
I'm having issues using The Fantastic Library. It works great in iray, but trying to load a 3Delight version is a nightmare. The preloads are both iray; Is there a way to switch the materials between Iray and 3Delight that’s less tedious than doing every single prop manually?
Thanks!!
  • Richard HaseltineRichard Haseltine Posts: 111,332
    You can multi-select items that need the same preset and change them all in one go. Once done you can save your own pre-load scene (or scene subset).
