Change and save a morph default. Plus dForce and heels.
N-RArtsN-RArts Posts: 1,609
edited May 2018 in The Commons
Hi,
I didn't want to post two seperate threads.
Morph Default:
I've got a head morph for Genesis 8 Female that loads in when I load in G8F. I've tried altering the default to 0%, but after restarting the program, it still loads in.
Is there a way of changing and saving the default so it doesn't automatically load in, in the future.
dForce & Shoes:
Is the high heel pose added before or after simulation? I bought a lovely long dress which I was going to use heels with (which will affect the height of the skirt).
Do I add the foot pose to a seperate frame of the animation or load it in with the pose or is there another way...?
Thanks for any help :)
Post edited by N-RArts on
  • LyonessLyoness Posts: 1,641
    In regards to dForce, it doesn't matter if the shoes are on before or after simulation.  They most likely will not effect anything.  If you are dealing with a floor length draping dress, then I would recommend applying the shoes before simulating.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    After resetting the default value did you resave it as an asset - File>Save As>Support Assets>Morph Asset, select the morph, leave the options as they are?
  • N-RArtsN-RArts Posts: 1,609
    Okay. Thank you smiley
    No. I just thought the Default would be saved automatically before I exited Daz.
    I've tried saving it as as Moph asset, and a modified morph asset, but it's still loading in at 100%. Maybe it's something I'm going to have to dial down myself, before I add anymore morphs to G8F.
