FSL Ultra Layered Makeups for Genesis 3 and 8 Female
DetniatDetniat Posts: 41
Hi there,
Having an issue with FSL Ultra Layered Makeups for Genesis 3 and 8 Female.  Some of the files are showing up in smart conten as "lost and found" and others seem to be missing thumbnails so I can't tell what I'm putting on the figure. I've attached a screen shot.
Thanks!
505 x 789 - 63K
Post edited by Detniat on
  • DetniatDetniat Posts: 41
    PS: I've uninstalled & reinstalled it and still having the same issue with this product.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Connect install or DIM?
    DIM
    If you right-click on it in the products list does it have an Install option or an Uninstall option?
    edited May 2018
    Thanks for trying to help, Richard.  It had an install option, so I clicked on that but I am still seeing the same things as my screen shot above.
    I also tried uninstalling from DIM & DS (It was still available in DS after uninstalling through DIM).  I then reinstalled through DS and am still seeing the same thing.  If you have other suggestions, I'll be happy to try them out.
    Thank you again.
  • RobotHeadArtRobotHeadArt Posts: 917
    Thank you again.
    I installed via DIM and see missing thumbnails as well.  I've opened a help ticket so hopefully they'll fix it and push out an update.
    The Install/Uninstall query was mainly as a double check that it hadn't been installed via Connect, as can happen if DS is connected and you open a product that it thinks isn't there. If you leave that Connect install you will need to update via Connect once the issue is fixed, assuming it isn't just metadata.
    Sorry you're having the same issue RobotHeadArt.  Thanks for the info, Richard.  I'll keep my eyes open for an update.
  • Hate to resurrect a dead thread, but I have a couple of questions.
    First, is this compatible with 3Delight? If so, how do you make the lipstick glossy?
    And is anyone out there nice enough to provide a list of the numbered components and name the color for each one? To help the colorblind. Not joking.
