Michael 4 Support folder could not be found
This happens with all my M4/V4 people. I've checked my content manager, and I have the poser content folder set right. I have a two folders actually - one for Daz downloads (DIM installed) and one for non-Daz downloads. Everything else, including clothes for these figures, loads fine.
  • Richard HaseltineRichard Haseltine Posts: 111,883
    It's looking for /Runtime/Libraries/!DAZ/Michael 4, in the content directory you are loading from.
  • It's looking for /Runtime/Libraries/!DAZ/Michael 4, in the content directory you are loading from.
    C:\Users\Public\Documents\My DAZ 3D Library\Runtime\Libraries\!DAZ\Michael 4 is full of files, so... ?
    C:\Users\Public\Documents\My DAZ 3D Library\Runtime\Libraries\Character\Daz People\Michael 4 is the figure you are loading?
  • C:\Users\Public\Documents\My DAZ 3D Library\Runtime\Libraries\Character\Daz People\Michael 4 is the figure you are loading?
    Yes. I just double checked it too and I'm fairly sure that's the only location for it.
    Mostly that error is down to instalaltion, but yours appears to be OK. it may be worth uninstalling and reinstall, just to be sure everything is in the correct place.
  • Mostly that error is down to instalaltion, but yours appears to be OK. it may be worth uninstalling and reinstall, just to be sure everything is in the correct place.
    I just uninstalled and reinstalled the base Michael 4 content. It didn't fix it. It seems to be installed correctly. Is it possible there's some sort of requirement that isn't installed by DIM?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,751
    there is a very simple answer to this but I have forgotten what it is blush
    something to do with file order
  • VIArtsVIArts Posts: 1,539
    edited May 2018
    in content direct9ory manager, the folder with m4 must be at the topm like this
    476 x 463 - 17K
    Post edited by VIArts on
  • in content direct9ory manager, the folder with m4 must be at the topm like this
    AH HA! That was it. Thank you so much!
    edited May 2018
    Mine isn't, though, and works (or did recently). That does suggest that a folder nearer the top of the list had some kind of bad install that was confusing the issue.
