Aiko 8
Will Vernea 8 work on Genesis 8 or do I have to have Aiko 8 as well????
  • 3Diva3Diva Posts: 12,058
    edited May 2018
    If it says that it requires Aiko 8 - it means it uses the Aiko 8 morph to help get it's shape. So while it would "work" on Genesis 8, the character's shape will look different without Aiko 8. Some characters that say "Requires ___" may only have that character's morph dialled in a small amount - but looking at Vernea it looks like she'd probably look quite different without the Aiko 8 character morph also.
    Post edited by 3Diva on
  • LeanaLeana Posts: 13,499
    The character will load and the texture should work, but the shape won't look the same without A8 since she's built off A8 shape.
  • lindanslindans Posts: 99
    Thanks guys, love the texture but don't want to splash out on Aiko 8. Hope there'll be a version for Genesis 8
    If you just want it for the texture, then you should get it - as the texture wouldn't need Aiko 8 - just the shape.
  • Right now I have a stack of stuff in my cart, Vernea being one of the items. I tend to build things up for a few days if I'm gonna buy things and then whittle it down as new sales pop up. If I end up pulling the trigger I'll post a screen shot of what she looks like without Aiko's morphs. But I've gotten characters in the past for shapes I don't have, and as others have said, they work just fine, but just look a bit different then the promo pics. Most of the time they look just fine without it. As for Vernea, she end up with a much larger chin and a less angular face overall I would image. You can test it yourself to get a feel for the kind of changes by just dialing back on the morphs of a character you already have that requires a different one.
  • Actually, here, this might help. This is Riza for Aiko and I just used her and dialed out Aiko. This is the kind of changes Vernea will probably have.
    1920 x 1080 - 429K
    1920 x 1080 - 465K
    1920 x 1080 - 1M
    1920 x 1080 - 1M
  • JessaiiJessaii Posts: 845
    You def dont need Aiko to use the textures, but she is about 60% of the morph. Here is a quicky without the Aiko morphs :) I am not used to doing brokers for non G8F figures so I always forget to include a G8F only render -.- Sorry about that!
    615 x 800 - 403K
    Thanks all, never sure what I can use with each figure.
  • dragotxdragotx Posts: 1,149
    I've got to learn to stop looking at the store at 3 in the morning, I just glazed over her and moved on.  But I just went back and looked at her again after your sample, and I think I may need to add her to my library
    She's quite beautiful, even without Aiko - lovely work! :)
