Sakura 8 causing problems.
This is a recent issue, as I have had Sakura 8 installed for months now, but there is something really weird happening with her base figure and other models.
If I load a Non Sakura store model, such as Aiko 8, when loading the figure, it loads it with a 100% Sakura Morph applied to the character. Similarly, when I load a custom character I have made with Sakura as a base, the Sakura morph does not load, and I have to turn it back up to 100% to get the figure right.
Any idea what may be going on?
Post edited by VonFunkensteinProductions on
  • Richard HaseltineRichard Haseltine Posts: 111,598
    The first part sounds as if the Sakura shape was resaved with a default value of 100%, or as if an additional morph was saved at 100% that is setting Sakura to 100%. Not sure why that would stop other characters from loading with the 100% value though. Reinstalling Sakura should overwrite any chnages in the base morph, so that's the first thing to try.
  • The first part sounds as if the Sakura shape was resaved with a default value of 100%, or as if an additional morph was saved at 100% that is setting Sakura to 100%. Not sure why that would stop other characters from loading with the 100% value though. Reinstalling Sakura should overwrite any chnages in the base morph, so that's the first thing to try.
    Thanks for your response, I just gave that a try. I uninstalled Sakura 8, and reinstalled it, and I am still getting the same issue.
  • As an additional note:
    If I uninstall Sakura 8, open up Daz, and load any female figure that is not the base Genesis figure, it still applies the Sakura Body morph, even though Sakura is uninstalled.
    How did you install, and uninstall?
  • Through the Install Manager
    Make sure you didn't have two copies of the files, especially those from the Data folder /data/DAZ 3D/Genesis 8/Female/Morphs/RareStone/Sakura 8/
  • Thanks for your help. There was a saved actor custom actor that had the Sakura morphs, so uninstalled Sakura again, deleted the character, and tried it again. The problem presisted, and went into the data folder to find out that the Rarestone folder had not been deleted in the uninstall, so I manually deleted that folder and reinstalled Sakura. Everything is back to normal.
