Daz Install Manager playing up.. [FIXED]
Ghosty12
Having issues with DiM, currently telling me that my password is incorrect yet it is correct.. And when I do get in it may or may not download and that if I download a few files one will download, and then the speed drops right off and then nothing.. And this is only since today, as before today it has been working fine so not sure what is up..
Update: DiM is all good now.. Thank you.. :)
Post edited by Ghosty12 on
DAZ Connect has been down most of the night, refusing log ons. So it's probably connected. No pun intended.
Ahh thank you I thought it was just me as keep getting login errors at the moment..
same problem
similar problem, can't login, yesterday it worked fine
We have reported this
que ce soit DIM ou avec studiot Daz 4.10 , impossible de se connecter , donc je présume que leurs serveurs est fermé
Y a t'il un reponsble pour nous informer de la situation
merci d'avance
Is there a way to use Daz Studio anyway?? The program is blocked on Logging In... I really need to work.
It should time out and start without connecting.
I'm having this problem as well, it's a relief to see that I'm not the only one. Thank you for reporting this, guys!
Yeah I was like that when I made this thread thinking am I the only one.. One of those weird type of things that happens every so often even though it is annoying at the time..
Same problem. Exact error s this
Unable to login to the specified account, Verify the email and or password and try again.
Je parle un peu francais. Moi aussi. Chohole a ecrit "La situation a ete rapportee.
Same symptoms here...Daz folks are probably just getting to work to fix this...while the rest of us just wait....
leave Daz long enough and it will fail to login and just start offline. It does take a few minutes though
Same issues.
I find that there is usually a choice "work offline" that you can check. No waiting needed.
