Greyscale to color photoshop question ...
WillowRaven
Someone here helped me figure this out over a year ago and I have since forgotten how the problem was solved ... I am hoping someone here can help me again :D
I have a bunch of greyscale png files of blood splatters that I need to change to color, but can't remember how.
Any help?
Photoshop > Hue/Saturation, tick "Colorize" and fiddle? The GIMP should have an equivalent somewhere.
Or, add a layer above the splatter, fill it with the desired color, and set the blend mode to Color.
I think I'm doing it wrong.
I'm using PS CS5.5 :D
Image Adjustments>Hue/Saturation, tick "Colorize," move the Saturation slider up so it doesn't stay grayscale, and play with the Hue slider.
EDIT: Make sure Image>Mode has RGB Color checked, not Grayscale.
Still not working.
Mode is RGB and the h/s sliders do nothing:
There aren't any layer styles to mess it up either. I'm stumped. Any chance you have an active selection? If not, does a Hue/Saturation adjustment layer work? Does changing the Hue slider have any effect on an already colored layer?
Failing everything else, you could try resetting preferences by holding Ctrl-Alt-Shift down when opening Photoshop. But if you have a lot of custom settings that may be less than ideal.
I figured it out by accident ... lol. I went into the fx blending option and chose cover overlay. Then I duplicated the layer to darken it.
It may not be the right way ... lol ... but it works ... lol.
