Can't load scene on start up
DUCKofDEATHDUCKofDEATH Posts: 0
I've read the previous messages that assist with the following error message when starting DAZ Studio 4.6, but the directory structure on my Mac isn't right:
Could not open the start up scene: /Users/cchris/Documents/DAZ 3D/Studio/My Library/People/Genesis/Genesis.dsf
File does not exist.
The "My Library" directory doesn't have a "People" directory in it. Do I need to reinstall DAZ Studio? I've already deinstalled and reinstalled twice.
I'm using a Mac Pro running OS X 10.8.4.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,348
    You may need to install Genesis Starter Essentials, if it isn't that it's there but in a different location, and you will need to change the extension to .duf.
  • DUCKofDEATHDUCKofDEATH Posts: 0
    edited July 2013
    Thanks for your reply! I had already installed the Starter Essentials, so I located the missing file and gave it a .duf extension.
    Now I'm getting the error "Missing Files: /data/DAZ 3D/Genesis/Base/Genesis.dsf"
    And when I try to run Elle, which I just bought, I get these errors:
    Missing Files
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/PBMNavelDepth.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Victoria 6/FBMVictoria6Body.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Head/PHMEyelashesLength.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Head/PHMEyelashesHideLayer1.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PBMNavel.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DeviousDolls/Elle/DD_ElleBody.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/FBMThin.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Victoria 6/FHMVictoria6Head.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/PBMNeckSize.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/CTRLGluteCrease.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Head/PHMEyelashesCurl.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/PBMWaistWidth.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/PBMBreastsCleavage.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Body/FBMVoluptuous.dsf
    /data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Evolution Head/PHMEyelashesTopPoint.dsf
    /data/DAZ 3D/Genesis 2/Female/Morphs/DeviousDolls/Elle/DD_Elle.dsf
    I'm thinking about returning Victoria 6 and Elle since I can't get them to install properly.
    Post edited by DUCKofDEATH on
    You need to install Genesis 2 Female Starter Essentials for V6
    As for Genesis.dsf, you DON'T want to rename the file in the Data folder, You want to to to Edit > Preferences > Startup > Startup Scene, click the browse button, and select Genesis.duf from that folder.
    According to the install manager, it's installed.
    edited July 2013
    I'm new at this and assumed I'd get reliable help on the forum. But you're telling me NOT to change the file name while the previous guy said:
    "You will need to change the extension to .duf."
    Will someone PLEASE give me some help I can use?
    You need to change the extension (and path, if it's wrong) in Edit>Preferences>Startup by clicking the name of the existing scene or preset and selecting Browse.... You want to select the file in the People\Genesis folder, not the file in the Data folder.
    I've decided to start fresh, so I uninstalled everything and only installed the Daz 3D studio stuff:
    DAZ Studio 4.6 (Mac 64-bit)
    Subsurface Shader Base
    Install Manager Default Filters
    Genesis Evolution: Head Morphs
    Genesis Evolution: Body Morphs
    So now I should have a default setup. Yet when Daz starts up, I get this message:
    Missing Files
    But there is a file called Genesis.dsf already there, so what is it looking for?
    And when I try to load any of the actors, I get these missing files errors:
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicFemale.dsf
    Why is it so difficult to get Daz 3D to locate the files it installed?
    DIM and DS do not use the same default content locations. Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
    Alrighty, the screen caps are attached.
    951 x 156 - 34K
    463 x 449 - 52K
    If you look at the second screenshot, DIM is installing to a location that isn't listed in the first screenshot, so DS can't find the data files. You can either add the DIM location in DS (to both the DAZ Studio Formats and Poser Formats), or else add the DS location to DIM and have DIM install to that location.
    edited July 2013
    Because I was going to delete DS to ensure I had a fresh copy with no modified filenames and such, I decided to change the default DIM install location to match that of DS: /Users/cchris/Documents/DAZ 3D/Studio/My Library. Then used DIM to uninstall and reinstall DS.
    When DS opened, it still couldn't find the Genesis.duf file, so I pointed it to the default location at /Users/cchris/Documents/.... Now it opens without error, but when I try to open an actor, it says "Could not open file : /Users/Shared/My DAZ 3D Library/People/Genesis/Characters/Basic Child.duf". Which is true, since I told DIM to install everything into DAZ Studio's supposedly default folder in /Users/cchris/Documents!
    Why is DS still looking for stuff in /Users/Shared? Is there a setting I missed?
    952 x 139 - 35K
    Go to the Installed tab in DIM, right-click on Genesis Starter Essentials, and select "Installed Files", and see where DIM thinks it installed them.
    Content (/Users/cchris/Documents/DAZ 3D/Studio/My Library) :
    /aniBlocks/aniMate/Dance/ankle_touch_and_point.ds
    /aniBlocks/aniMate/Dance/ankle_touch_and_point.gfa
    /aniBlocks/aniMate/Dance/double_touch_and_point.ds
    /aniBlocks/aniMate/Dance/double_touch_and_point.gfa
    /aniBlocks/aniMate/Dance/idle_dance_in_place.ds
    /aniBlocks/aniMate/Dance/idle_dance_in_place.gfa
    /aniBlocks/aniMate/Dance/lean_forward_and_point.ds
    /aniBlocks/aniMate/Dance/lean_forward_and_point.gfa
    /aniBlocks/aniMate/Dance/lockin_arm_and_leg.ds
    /aniBlocks/aniMate/Dance/lockin_arm_and_leg.gfa
    /aniBlocks/aniMate/Dance/lockin_combo.ds
    /aniBlocks/aniMate/Dance/lockin_combo.gfa
    /aniBlocks/aniMate/Dance/roll_and_point.ds
    /aniBlocks/aniMate/Dance/roll_and_point.gfa
    /aniBlocks/aniMate/Dance/spin.ds
    /aniBlocks/aniMate/Dance/spin.gfa
    /aniBlocks/aniMate/Dance/staying_alive.ds
    /aniBlocks/aniMate/Dance/staying_alive.gfa
    /aniBlocks/aniMate/Fighting/boxing.ds
    /aniBlocks/aniMate/Fighting/boxing.gfa
    /aniBlocks/aniMate/Fighting/kick-(A).ds
    /aniBlocks/aniMate/Fighting/kick-(A).gfa
    /aniBlocks/aniMate/Fighting/kick-(B).ds
    /aniBlocks/aniMate/Fighting/kick-(B).gfa
    /aniBlocks/aniMate/Fighting/kiss_slap-(A).ds
    /aniBlocks/aniMate/Fighting/kiss_slap-(A).gfa
    /aniBlocks/aniMate/Fighting/kiss_slap-(B).ds
    /aniBlocks/aniMate/Fighting/kiss_slap-(B).gfa
    /aniBlocks/aniMate/Fighting/punch.ds
    /aniBlocks/aniMate/Fighting/punch.gfa
    /aniBlocks/aniMate/Fighting/push-(A).ds
    /aniBlocks/aniMate/Fighting/push-(A).gfa
    /aniBlocks/aniMate/Fighting/push-(B).ds
    /aniBlocks/aniMate/Fighting/push-(B).gfa
    /aniBlocks/aniMate/Fighting/slap-(A).ds
    /aniBlocks/aniMate/Fighting/slap-(A).gfa
    /aniBlocks/aniMate/Fighting/slap-(B).ds
    /aniBlocks/aniMate/Fighting/slap-(B).gfa
    /aniBlocks/aniMate/Gestures/bow.ds
    /aniBlocks/aniMate/Gestures/bow.gfa
    /aniBlocks/aniMate/Gestures/clap.ds
    /aniBlocks/aniMate/Gestures/clap.gfa
    /aniBlocks/aniMate/Gestures/get_outta_here.ds
    /aniBlocks/aniMate/Gestures/get_outta_here.gfa
    /aniBlocks/aniMate/Gestures/high_five-(A).ds
    /aniBlocks/aniMate/Gestures/high_five-(A).gfa
    /aniBlocks/aniMate/Gestures/high_five-(B).ds
    /aniBlocks/aniMate/Gestures/high_five-(B).gfa
    /aniBlocks/aniMate/Gestures/shoulder_pat-(A).ds
    /aniBlocks/aniMate/Gestures/shoulder_pat-(A).gfa
    /aniBlocks/aniMate/Gestures/shoulder_pat-(B).ds
    /aniBlocks/aniMate/Gestures/shoulder_pat-(B).gfa
    /aniBlocks/aniMate/Gestures/tantrum.ds
    /aniBlocks/aniMate/Gestures/tantrum.gfa
    /aniBlocks/aniMate/Ups & Downs/crouch_and_jump.ds
    /aniBlocks/aniMate/Ups & Downs/crouch_and_jump.gfa
    /aniBlocks/aniMate/Ups & Downs/jump.ds
    /aniBlocks/aniMate/Ups & Downs/jump.gfa
    /aniBlocks/aniMate/Ups & Downs/kneel_idle.ds
    /aniBlocks/aniMate/Ups & Downs/kneel_idle.gfa
    /aniBlocks/aniMate/Ups & Downs/kneel_to_stand.ds
    /aniBlocks/aniMate/Ups & Downs/kneel_to_stand.gfa
    /aniBlocks/aniMate/Ups & Downs/sit_in_chair.ds
    /aniBlocks/aniMate/Ups & Downs/sit_in_chair.gfa
    /aniBlocks/aniMate/Ups & Downs/stand_to_kneel.ds
    /aniBlocks/aniMate/Ups & Downs/stand_to_kneel.gfa
    /aniBlocks/aniMate/Ups & Downs/stand_up.ds
    /aniBlocks/aniMate/Ups & Downs/stand_up.gfa
    /aniBlocks/aniMate/Walks/corner left.ds
    /aniBlocks/aniMate/Walks/corner left.gfa
    /aniBlocks/aniMate/Walks/corner right.ds
    /aniBlocks/aniMate/Walks/corner right.gfa
    /aniBlocks/aniMate/Walks/forward_(1_cycle).ds
    /aniBlocks/aniMate/Walks/forward_(1_cycle).gfa
    /aniBlocks/aniMate/Walks/start-(N).ds
    /aniBlocks/aniMate/Walks/start-(N).gfa
    /aniBlocks/aniMate/Walks/stop-(N).ds
    /aniBlocks/aniMate/Walks/stop-(N).gfa
    /aniBlocks/aniMatePlus/character/ps-ball_up.ds
    /aniBlocks/aniMatePlus/character/ps-ball_up.gfa
    /aniBlocks/aniMatePlus/character/ps-hunch.ds
    /aniBlocks/aniMatePlus/character/ps-hunch.gfa
    /aniBlocks/aniMatePlus/character/ps-leg_out.ds
    /aniBlocks/aniMatePlus/character/ps-leg_out.gfa
    /aniBlocks/aniMatePlus/character/ps-lift_arms.ds
    /aniBlocks/aniMatePlus/character/ps-lift_arms.gfa
    /aniBlocks/aniMatePlus/character/ps-proud.ds
    /aniBlocks/aniMatePlus/character/ps-proud.gfa
    /aniBlocks/aniMatePlus/character/ps-widen_stance.ds
    /aniBlocks/aniMatePlus/character/ps-widen_stance.gfa
    /aniBlocks/aniMatePlus/character/v4-v3.ds
    /aniBlocks/aniMatePlus/character/v4-v3.gfa
    /aniBlocks/aniMatePlus/expression/v4-BrowSqueeze.ds
    /aniBlocks/aniMatePlus/expression/v4-BrowSqueeze.gfa
    /aniBlocks/aniMatePlus/expression/v4-EyesSquint.ds
    /aniBlocks/aniMatePlus/expression/v4-EyesSquint.gfa
    /aniBlocks/aniMatePlus/expression/v4-LipsPucker.ds
    /aniBlocks/aniMatePlus/expression/v4-LipsPucker.gfa
    /aniBlocks/aniMatePlus/expression/v4-MouthFrown.ds
    /aniBlocks/aniMatePlus/expression/v4-MouthFrown.gfa
    /aniBlocks/aniMatePlus/expression/v4-MouthSmile.ds
    /aniBlocks/aniMatePlus/expression/v4-MouthSmile.gfa
    /aniBlocks/aniMatePlus/expression/v4-MouthSmileOpen.ds
    /aniBlocks/aniMatePlus/expression/v4-MouthSmileOpen.gfa
    /aniBlocks/aniMatePlus/expression/v4-MouthSneer.ds
    /aniBlocks/aniMatePlus/expression/v4-MouthSneer.gfa
    /aniBlocks/aniMatePlus/expression/v4-NoseWrinkle.ds
    /aniBlocks/aniMatePlus/expression/v4-NoseWrinkle.gfa
    /aniBlocks/aniMatePlus/expression/v4-TongeLickLips.ds
    /aniBlocks/aniMatePlus/expression/v4-TongeLickLips.gfa
    /aniBlocks/aniMatePlus/expression/v4-TongeStickOut.ds
    /aniBlocks/aniMatePlus/expression/v4-TongeStickOut.gfa
    /aniBlocks/aniMatePlus/light/cl-black.ds
    /aniBlocks/aniMatePlus/light/cl-black.gfa
    /aniBlocks/aniMatePlus/light/cl-blue.ds
    /aniBlocks/aniMatePlus/light/cl-blue.gfa
    /aniBlocks/aniMatePlus/light/cl-green.ds
    /aniBlocks/aniMatePlus/light/cl-green.gfa
    /aniBlocks/aniMatePlus/light/cl-red.ds
    /aniBlocks/aniMatePlus/light/cl-red.gfa
    /aniBlocks/aniMatePlus/light/cl-white.ds
    /aniBlocks/aniMatePlus/light/cl-white.gfa
    /aniBlocks/aniMatePlus/light/lt-pulse.ds
    /aniBlocks/aniMatePlus/light/lt-pulse.gfa
    /aniBlocks/aniMatePlus/light/lt-strobe.ds
    /aniBlocks/aniMatePlus/light/lt-strobe.gfa
    /aniBlocks/aniMatePlus/living/v4-Blink.ds
    /aniBlocks/aniMatePlus/living/v4-Blink.gfa
    /aniBlocks/aniMatePlus/living/v4-BlinkTwice.ds
    /aniBlocks/aniMatePlus/living/v4-BlinkTwice.gfa
    /aniBlocks/aniMatePlus/living/v4-breath_nod.ds
    /aniBlocks/aniMatePlus/living/v4-breath_nod.gfa
    /aniBlocks/aniMatePlus/object/rt-hold_still.ds
    /aniBlocks/aniMatePlus/object/rt-hold_still.gfa
    /aniBlocks/aniMatePlus/object/rt-rotateY_90.ds
    /aniBlocks/aniMatePlus/object/rt-rotateY_90.gfa
    /aniBlocks/aniMatePlus/object/rt-translateX.ds
    /aniBlocks/aniMatePlus/object/rt-translateX.gfa
    /aniBlocks/aniMatePlus/object/rt-translateY.ds
    /aniBlocks/aniMatePlus/object/rt-translateY.gfa
    /aniBlocks/aniMatePlus/object/rt-translateZ.ds
    /aniBlocks/aniMatePlus/object/rt-translateZ.gfa
    /aniBlocks/aniMatePlus/visibility/rt-invisible.ds
    /aniBlocks/aniMatePlus/visibility/rt-invisible.gfa
    /aniBlocks/aniMatePlus/visibility/rt-visible.ds
    /aniBlocks/aniMatePlus/visibility/rt-visible.gfa
    /Animals/Millennium SubDragon/Materials/Sample-Res/MAT SubDragon SAMPLE.duf
    /Animals/Millennium SubDragon/Materials/Sample-Res/MAT SubDragon SAMPLE.png
    /Animals/Millennium SubDragon/SubDragon LE.duf
    /Animals/Millennium SubDragon/SubDragon LE.png
    /Camera Presets/Alchemy Chasm/Camera1.duf
    /Camera Presets/Alchemy Chasm/Camera1.png
    /Camera Presets/Alchemy Chasm/Camera2.duf
    /Camera Presets/Alchemy Chasm/Camera2.png
    /Camera Presets/Alchemy Chasm/Camera3.duf
    /Camera Presets/Alchemy Chasm/Camera3.png
    /Camera Presets/Alchemy Chasm/Camera4.duf
    /Camera Presets/Alchemy Chasm/Camera4.png
    /Camera Presets/Alchemy Chasm/Camera5.duf
    /Camera Presets/Alchemy Chasm/Camera5.png
    /Camera Presets/Alchemy Chasm/Camera6.duf
    /Camera Presets/Alchemy Chasm/Camera6.png
    /data/3_0/environmentSphere_1923/environmentSphere_1923/geometry.dso
    /data/3_0/environmentSphere_1923/environmentSphere_1923/maps/.dsv
    /data/3_0/environmentSphere_1923/environmentSphere_1923/uvs/.dsv
    /data/3_0/omCone1m24/omCone1m24/maps/uv.dsv
    /data/3_0/omCone1m24/omCone1m24/omCone1m24.dso
    /data/3_0/omCone1m24/omCone1m24/uvs/default.dsv
    /data/3_0/omLightDisc/omLightDisc/maps/uv.dsv
    /data/3_0/omLightDisc/omLightDisc/omLightDisc.dso
    /data/3_0/omLightDisc/omLightDisc/uvs/default.dsv
    /data/3_0/omLightPlane/omLightPlane/maps/uv.dsv
    /data/3_0/omLightPlane/omLightPlane/omLightPlane.dso
    /data/3_0/omLightPlane/omLightPlane/uvs/default.dsv
    /data/3_0/omLightSphere/omLightSphere/maps/uv.dsv
    /data/3_0/omLightSphere/omLightSphere/omLightSphere.dso
    /data/3_0/omLightSphere/omLightSphere/uvs/default.dsv
    /data/3_0/omLightTube/omLightTube/maps/uv.dsv
    /data/3_0/omLightTube/omLightTube/omLightTube.dso
    /data/3_0/omLightTube/omLightTube/uvs/default.dsv
    /data/3_0/omNeonOmni/omNeonOmni/maps/uv.dsv
    /data/3_0/omNeonOmni/omNeonOmni/omNeonOmni.dso
    /data/3_0/omNeonOmni/omNeonOmni/uvs/default.dsv
    /data/3_0/omSphere1m16x24/omSphere1m16x24/maps/uv.dsv
    /data/3_0/omSphere1m16x24/omSphere1m16x24/omSphere1m16x24.dso
    /data/3_0/omSphere1m16x24/omSphere1m16x24/uvs/default.dsv
    /data/DAZ 3D/Aikanaro/NoAi-Columnwall/NoAi-columnwall.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Columnwall/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Fence/NoAi-fence.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Fence/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Ground/NoAi-ground.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Ground/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Post/NoAi-post.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Post/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Vase/NoAi-vase.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Vase/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Wall/NoAi-wall.dsf
    /data/DAZ 3D/Aikanaro/NoAi-Wall/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Archpillar_L/ac_archpillarL_7577.dsf
    /data/DAZ 3D/Alchemy Chasm/Archpillar_L/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Archpillar_R/ac_archpillarR_7568.dsf
    /data/DAZ 3D/Alchemy Chasm/Archpillar_R/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Cavern/ac_cavern_2162.dsf
    /data/DAZ 3D/Alchemy Chasm/Cavern/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Ceiling/ac_ceiling_24.dsf
    /data/DAZ 3D/Alchemy Chasm/Ceiling/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Corridor/ac_corridor_348.dsf
    /data/DAZ 3D/Alchemy Chasm/Corridor/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Doorway/ac_doorway_1376.dsf
    /data/DAZ 3D/Alchemy Chasm/Doorway/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Innerwall_L/ac_innerwallL_34549.dsf
    /data/DAZ 3D/Alchemy Chasm/Innerwall_L/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Innerwall_R/ac_innerwallR_30463.dsf
    /data/DAZ 3D/Alchemy Chasm/Innerwall_R/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Outerwall_L/ac_outerwallL_5010.dsf
    /data/DAZ 3D/Alchemy Chasm/Outerwall_L/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Outerwall_R/ac_outerwallR_4692.dsf
    /data/DAZ 3D/Alchemy Chasm/Outerwall_R/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Platform/ac_platform_3416.dsf
    /data/DAZ 3D/Alchemy Chasm/Platform/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Alchemy Chasm/Stand/stand_1370.dsf
    /data/DAZ 3D/Alchemy Chasm/Stand/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Aldora for Genesis.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/AllFuller.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FBMBasicChild.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FBMBasicFemale.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FBMBasicMale.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FBMHeavy.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FHMAlienHumanoid.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FluffOut.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/FluffRBangs.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/HeadLonger.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/LBangsForward.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/LBangsLonger.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/LeftOut.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/LWispForward.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/PHMEarsAngle.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/PHMEarsHeight.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/RBangsLonger.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/RFrameCheeks.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/RightOut.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/RSideLong.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/RWispForward.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/SweepBangsL.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/Windy.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/WispsForward.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/Morphs/DAZ 3D/Base/WispsLonger.dsf
    /data/DAZ 3D/Aldora Hair/Aldora for Genesis/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/BlueMarble/BlueMarb.dsf
    /data/DAZ 3D/Built-in Content/Brick/Brick.dsf
    /data/DAZ 3D/Built-in Content/Chrome/Chrome.dsf
    /data/DAZ 3D/Built-in Content/Clouds/Clouds.dsf
    /data/DAZ 3D/Built-in Content/Disc/omLightDisc.dsf
    /data/DAZ 3D/Built-in Content/Disc/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Environment Sphere/environmentSphere_1923.dsf
    /data/DAZ 3D/Built-in Content/Environment Sphere/UV Sets/DAZ 3D/Base/uvset_1.dsf
    /data/DAZ 3D/Built-in Content/Flagstone/Flag Stones.dsf
    /data/DAZ 3D/Built-in Content/FractalSum/Mixed Fractual Sum.dsf
    /data/DAZ 3D/Built-in Content/Glass/Caustic Glass.dsf
    /data/DAZ 3D/Built-in Content/Light Disc/omLightDisc.dsf
    /data/DAZ 3D/Built-in Content/Light Disc/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Light Neon/omNeonOmni.dsf
    /data/DAZ 3D/Built-in Content/Light Neon/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Light Plane/omLightPlane.dsf
    /data/DAZ 3D/Built-in Content/Light Plane/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Light Sphere/omLightSphere.dsf
    /data/DAZ 3D/Built-in Content/Light Sphere/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Light Tube/omLightTube.dsf
    /data/DAZ 3D/Built-in Content/Light Tube/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/MarbleGraniteTile/TiledMarble.dsf
    /data/DAZ 3D/Built-in Content/Orange Toon/Orange Toon.dsf
    /data/DAZ 3D/Built-in Content/Scenes/omVolumeCone.duf
    /data/DAZ 3D/Built-in Content/Scenes/omVolumeSphere.duf
    /data/DAZ 3D/Built-in Content/Simple Skin/Simple Skin.dsf
    /data/DAZ 3D/Built-in Content/Subsurface Stone/Subsurface Stone.dsf
    /data/DAZ 3D/Built-in Content/TiledTextureSetup/Tiling Textrue Setup.dsf
    /data/DAZ 3D/Built-in Content/Volume Cone/omCone1m24.dsf
    /data/DAZ 3D/Built-in Content/Volume Cone/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/Volume Sphere/omSphere1m16x24.dsf
    /data/DAZ 3D/Built-in Content/Volume Sphere/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Built-in Content/WeaveDisplacement/Weave Displace.dsf
    /data/DAZ 3D/Built-in Content/Wood/Wood.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Duke for Genesis.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/ADJ Backhead out.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/ADJ BackNECKout.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/ADJ Ears Out.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/ADJ Front out upper.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/ADJ Front out.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Backhairs longer.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/FBMBasicChild.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/FBMBasicFemale.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/FBMBasicMale.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/FHMAlienHumanoid.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 01.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 02.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 03.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 04.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 05.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Front style 06.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Fuller Style.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Style front at Nose out.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Style sides shorter.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/Morphs/DAZ 3D/Base/Style top ones jumping.dsf
    /data/DAZ 3D/Duke Hair/Duke for Genesis/UV Sets/DAZ 3D/Base/default.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneAiko4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneFreak4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneHiro4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneKids4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneMichael4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneRebySky.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneStephanie4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneTheGirl4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CloneVictoria4.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLAngry.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownLeft.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownRight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsFrntBck.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsFrntBckLeft.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsFrntBckRight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsUpDwn.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsUpDwnLeft.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsUpDwnRight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsUpLeft.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsUpRight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowInnerUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowOuterUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowSqueeze.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLBrowUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksBalloon.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksBalloonPucker.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksCrease.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksCreaseL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksCreaseR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksEyeFlex.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksEyeFlexL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksEyeFlexR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksFlex.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksFlexL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLCheeksFlexR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLConcentrate.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsBottomUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyeLidsTopUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesClosed.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesClosedL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesClosedR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesSquint.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesSquintL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesSquintR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLEyesUpDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLFear.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLGlare.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLHipBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLHipBendBck.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLHipBendFwd.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawIn.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawInOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawSideL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLJawSideR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLegsOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFingersFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFingersGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFingersInOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFingersStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFootRoll.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlFootTwist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlHandFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlHandGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlHandSpread.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlHandStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlIndexBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomIn.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomInL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomInR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomOutL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomOutR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipBottomUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipsPart.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipsPartCenter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipsPucker.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipsPuckerWide.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopUp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopUpL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLLipTopUpR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlLegOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlMidBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlPinkyBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlRingBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlThumbBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlThumbFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlThumbGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlThumbInOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLlThumbStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthCornerUpDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthFrown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthNarrow.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthNarrowL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthNarrowR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthOpen.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthOpenWide.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthSide-SideL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthSide-SideR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthSmile.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLMouthSmileOpen.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLNeckHeadBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLNeckHeadSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLNeckHeadTwist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLNoseWrinkle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLNostrilsFlare.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFingersFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFingersGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFingersInOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFingersStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFootRoll.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrFootTwist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrHandFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrHandGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrHandSpread.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrHandStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrIndexBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrLegOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrMidBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrPinkyBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrRingBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrThumbBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrThumbFist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrThumbGrasp.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrThumbInOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLrThumbStraighten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLShldrsFrntBck.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLShouldersShrug.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLSmileSimple.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLSmileSimpleL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLSmileSimpleR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMAA.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMEH.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMER.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMF.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMIH.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMIY.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMK.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSML.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMM.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMOW.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMS.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMSH.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMT.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMTH.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMUW.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLVSMW.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLWaistBend.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLWaistSide.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLWaistTwist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicChild.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicChild.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicFemale.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicMale.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBasicMale.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBodybuilder.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBodybuilder.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/FBMBodyVolume.dsf
    There's more stuff, let me know if I didn't post what you needed.
    I'm guessing you still have old links left over. In DS in the Content Library tab > options menu (the rectangle with horizontal lines in the upper corner) > Content DB Maintenance > Remove Unmapped Base Paths and Orphans and see if that cleans up the bad links
