Looking for a decent Kaiju tail
Hello peoples! I wonder if any of you might be able to offer any advice here.
I'm trying to find a good thick monster like tail that I can attach to a Genesis figure, I thought that I could use the TyRex tail http://www.daz3d.com/tyrex but its not long enough for what I'm looking for. Tried lengthening it but that doesn't seem to work (even when trying to enlarge just a section at a time) Catgirl and wolfie tails don't produce the same kind of effect so I'm kinda stuck.
Anyone know where I might find something along the lines of a longer TyRex tail?
Oh, I also tried using the Stegosaur tail, which would suit but again I can find no way to lengthen it out to the proportions I need :(
Any advice would be greatly appreciated!
Maybe this set would help http://www.daz3d.com/kaiju-the-giant-monster ... It also has add-ons http://www.daz3d.com/monster-maul-kaiju-add-ons
I thought of that, already have it downloaded. Sadly though its not what I'm after :(
Thanks though!
There is this set for the original Freak that might work for you, http://www.daz3d.com/dragonman
Can I just use the tail from that and attach it to a standard Genesis figure? Or will I need the Freak 3 morphs for Genesis first?
if you have a dino or other figure with the tail you want, turn it all invisible except for the tail, parent to genesis' pelvis, move the tail so there no gaps... you'll need to either texture genesis or the tail to make them match.... I've sometimes grabbed a bit of skin from a genesis texture, and then tiled it on the tail to make it a workable kitbash.
Alternatively, use the awesome new http://www.daz3d.com/new-releases/sculptural-genesis-ultra-fun-kit, which gives genesis a new UV map that makes it perfect for tiles (such as Calida's scale tiles, which I would link to, but the store link for Calida's store seems to be broken).
You can just add the tail. I haven't done this but it should work OK. It would be better if you had the Freak 3 for Genesis morph to allow the autofit to work but it might be OK otherwise. But you can also just parent it, which is what you would be doing for other options.
